Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
Master Cylinder Brake Lines
« previous
next »
Print
Pages: [
1
Author
Topic: Master Cylinder Brake Lines (Read 3493 times)
69RALLYSPORTZ28
Member
on:
July 11, 2020, 11:59:20 PM »
Are there supposed to be looped brake lines leading from the Master Cylinder and proportioning valve to the brake lines to each wheel?
Is this typical of a decades old replacement of Master Cylinder?
Here is the link to the Z/28
https://pacificclassics.com/inventory/1969-chevrolet-camaro-z28-rally-sport/
Tweet
Logged
Danzo
Hero Member
Re: Master Cylinder Brake Lines
Reply #1 on:
July 12, 2020, 12:52:31 AM »
Master cylinder is incorrect, should have bleeder screws Picture shows brake line routing.
Doc
Logged
Hero Member
Reply #2 on:
July 14, 2020, 04:17:21 PM »
The pic Dan provided also shows the metering valve in the right spot. I don't see where it is in your pic . (corrected, thanks Gary)
Last Edit: July 14, 2020, 04:52:20 PM by BULLITT65
Logged
Hero Member
owner since 4-Apr-1976
Reply #3 on:
July 14, 2020, 04:38:24 PM »
Austin: The proportioning valve if used is mounted on the frame rail under the driver. The parts mounted just under the MC are described in JohnZ's brake article... go read it..
ie.. hold off valve, differential switch, metering valve etc...
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
1stgen68
Member
Reply #4 on:
July 14, 2020, 09:19:57 PM »
Those aren't proportioning valves. They are distribution blocks. They essentially do nothing but route juice and do not say you get this much in the back and you get this much in the front.
Logged
Print
Pages: [
1
« previous
next »
Originality
