Author Topic: 1967 Badge datum line identification  (Read 3671 times)
« on: April 27, 2020, 01:18:17 AM »
  I'm helping a friend drill a fender for the 327 w/flags badge. In looking at the AIM below I see two datum lines #5 and #15. The #5 line is referenced from the center hole for the CAMARO badge, so that easy to locate. But the #15 line is of question. I can't see in the AIM page where it's referenced from to determine the base.
  Any help is surely appreciated!
Re: 1967 Badge datum line identification
« Reply #1 on: April 27, 2020, 01:23:44 AM »
READ THIS from John. You'll need to find someone with a 327 car and original fenders to get the correct dimensions.
« Reply #2 on: April 27, 2020, 01:56:36 AM »
 Thanks, Ed.  There are no original references to use.
  Reading about the firewall being the 0 reference point, I remembered seeing something in the AIM. I found page UPC 11-13/B8 with the references. So, from studying the AIM, what I think may be a valid starting point is approximately 10.03" from the bottom of the fender just behind the wheel opening (15 - 4.07 = 10.03).
Thanks!
