Author Topic: 68 engine compartment detailing  (Read 9615 times)
steve's 68
« on: May 28, 2019, 05:34:27 PM »
I am a new member of the CRG and am extremely impressed with your site! I am working on the engine compartment of my 68 SS and would appreciate detail photos of wiring harness on DS inner fender, clips, ties etc and wiring on the PS of the radiator support.  There seems to be a clip on the lower right corner of the heater box that I cannot find, any suggestions?  Lastly, is there a compilation of all of the bolts and screw in the engine compartment, configuration, pointed or blunt, head markings etc.  seems I have quite a variety on my car.  Thanks.
hrlyfxdl
Re: 68 engine compartment detailing
« Reply #1 on: May 28, 2019, 08:56:00 PM »
Getting a 68 Camaro AIM is very handy and will address alot of the search for the hardware, and you can cross that with AMK products to find reproduction hardware. Or PM me and I can give you a contact of a gent that sells a lot of original hardware for Camaros, if that is what you are seeking. And hard to find clips as well. Welcome to the site BTW, I'm relatively new as well and everyone has been great and extremely helpful.
1968 Camaro SS 350 8L34677?
07A  E107  TR 712  U-U
5hane
« Reply #2 on: May 31, 2019, 12:07:26 AM »
Obtain the AIM as Shane suggested and search topics both here and team Camaro. Here is a list of hardware I put together while restoring our 68.
FIRST GENERATION CAMARO FASTENERS-68/69 AIM Fastener Part #'s Note: 68 assumed and 69 noted
 Screws
 0103321-P319, P320 3/8" lock washer AMK B-13052 (25) .38X.68 X.105thk
 0159853-P98
 0174916-1/4" Toothed Lock Washer w/9420415 screw (elect grounds), 69 AIM pages-28, 155, 156, 161, 182, 439, 440, 441, 460 AMK B-11314 (Cool
 0187875-P155
 0274430-P91
 0447143- P39/91/162 (69 AIM UPC 1 A5) Hex screw 8-18X1/4 .34" O.D. AMK- B-11070 (20pcs) 0456766-P237 front spoiler #10-12X5/8 5/16 AF .4 O.D. Noted some originals had “D” in hex head.
 0585842-P44 AMK N/A
 1359887-P144, P366 5/16-18 1/2AF .67OD .28THK muffler clamp/hood leveler nut AMK B-12891 (6)
 1363900-P119
 3748038-P94 Motor Mt RH 3/8-16X7/8 9/16 AF .65 split B-12456 (2) B-12456 (2)
 3749084-P319 Wire retainer (shift rods) AMK B-13390 (3) B-11574 (10)
 3758783-P149 Battery hold down clamp bolt- AMK has no reference by GM part#
 3768390-P94 3/8-16X1 1/8 9/16 AF .65 split AMK B-12458 (2)
 3778526-P99 Fuel Pump 3/8-16X1 1/2 9/16 AF .65 split AMK B-10904 (2)
 3784303-P68/118 5/16-18X7/8 1/2 AF .55 split similar B-10913 (2)
 3786494-P94 Motor Mt LH 3/8-16X1.0 9/16 AF .55 split B-10907
 3817006-P99 Timing cover & oil pan correct 1/4-20X7/16 7/16AF .44 external B-10881 (10)
 3821961-P46 AMK N/A
 3824124-P36 Zinc/Wiper Motor 10-24X1.0 .33 external AMK B-12298 (6)
 3831892-P178 3/8-16X1 1/8 9/16AF 1.0 Conical "f' head AMK B-11718 (2)
 3837950-P124
 3839682-P144 hood leveler screw 5/16-18X1 3/8 .59 OD AMK B-10396 (2)
 3839741-P135/142 3/8-16X1 3/8 1.31 Conical AMK B-11964 (4) Head Marking circled E?
 3841230-P73/123 10-16X1/2 5/16 AF .4 O.D. AMK B-10511 (4)
 3841497-P319 7/16-20 9/16 AF .22thk AMK B-10511 (4)
 3846201-Pages 147 & 206 (69 AIM) 5/16-18X5/8 .75 Conical AMK B-12545 (5) Support bar to radiator support. Note: 2 orig. 69's had same bolt in both ends of support bar
 3846202-Pages 61/63/73/144/145 5/16-18X7/8 .75 Conical AMK 'E', B-13317 (6) & B-10876 (12) & 'C' type B-11709 (6) & B-11710 (12) Note: Both head marks acceptable.
 3847757-P127/141
 3847758-P143 thread design not correct 5/16-18X1 1/16 1/2 AF .75 conical AMK B-11549 (2)
 3848408-P91
 3849634-P45/153 Stainless 8-18X5/8 .27 O.D. AMK B-11117 (12)
 3853846-P155 Zinc/horns- 5/16-18X7/8 .75 toothed AMK Anchor head-marked screw B-10900 (2)
 3856065-P141
 3856691-P74 1/4-20X5/8 7/16 AF .62 conical Mfg marking not correct AMK B-10800 (6)
 3857663-P135 3/8-16X1 3/8 1.0 Conical AMK B-11387 (4) B-11874 (12)
 3858195-P186 8-18X3/8 1/4AF .34 O.D. AMK B-12049 (20)
 3858700-P229
 3863392-P53 10-16X3/4 5/16AF .4 O.D. AMK B-11090 (Cool
 3863393-P52 1/4-14X1.0 7/16AF .69 External Zinc AMK B-11200 (2) or B-11201 (6)
 3872454-P49 Similar 3/8-16X15/16 9/16AF .88 Conical AMK B-11717 (2)
 3873950-P55, 56 Top Hat Screw 10-16X5/8 1/4AF .42 O.D. AMK B-11089 (Cool
 3873951-P166 10-16X5/8 1/4AF .42 O.D. Top hat style AMK B-11088 (Cool
 3873999-P188
 3876129-P92 Voltage Regulator 10-24X1.0 5/16AF .5 O.D. AMK B-10011
 3899538- P141 5/16-18X7/8 1.5 Conical AMK B-11600 (2) & B-11601 (6)
 3899718-P56
 3903536-P145 LH side only radiator 1/4-20X13/16 3/8AF .51OD AMK B-10384 (2)
 3903539-P145 LH side only radiator sp/nut 1/4-20 .50X.63 L body ,.73 OD flange AMK B-10608 (2)
 3904859-P42 Nut AMK N/A
 3909140-P68/179 3/8-16X1 1/8 9/16AF 1.12 Conical AMK B-11719 (2)
 3910700-P320 shifter/shock rubber grommet AMK B-10237 (4)
 3918503-P68 3/8-16X1 1/8 9/16AF .8 Conical AMK B-10877 (4)
 3919053-P160
 3919089-P40, 48, 53 Dash Mat trim cover screws AMK N/A
 3921445-P153
 3922549-P360 5/16-18X7/8 1/2AF .55 split AMK B10913 (2) see 9409098 for alt.
 3933052-P36 Zinc/Wiper Arm Pivots 10-24X1/2 .33 external AMK B-10884 (4)
 3958062/9420825- 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip screw AMK-Anchor B-10416 (4)
 3963329- 3/8-16X1 1/2 1.12 Conical AMK B-11720 (2)
 3986563- 3/8-16X1 1/4 1.31 Conical AMK B-11964 (4)
 5544049-P320 .64 X 2.10 Shock/shifter stab. retainer AMK B-11235 (4) B-11236 (10)
 9409098-Could be used for 3922549 if zinc removed and phosphated AMK B-12321 (2)
 9409107-P171/361/366 1/4-20X5/8 7/16AF .44 split AMK B-12303 (4)
 9411890-P119
 9414252-10-16X5/8 .36 O.D. AMK B-12220 (10)
 9414724-P172 10-16X3/4 .37 O.D. Zinc/AMK B-12197 (10) Note: Same screw available in Phosphate
 9414752-P51 8-18X1/2 .27O.D. chrome screw AMK B-12116 (12)
 9414754-P51 8-18X3/4 .27O.D. chrome screw AMK B-12123 (12)
 9414763-10-16X5/8 .31 OD AMK B11135 (10)
 9414764-10-16X3/4 .31 O.D. AMK B-11136 (Cool
 9414766-10-16X1.0 .31 O.D. AMK B-12225 (6)
 9414767-10-16-X1 1/4 .31 O.D. AMK B-12227 (6)
 9415464-P161 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40)
 9416208-P47 8-18X3/4 .31 O.D. AMK Stainless & Chrome B-12124 (10) B-11524 (50) Note: Sill Plate Screws
 9416822-10-16X1 1/4 .36 O.D. AMK B-12228 (6)
 9417318-10-12X1 1/2 .36 O.D. AMK B-12229 (4)
 9417706-P186
 9417986-same as 9416208
 9418359-P262 8-18X1/2 .31 O.D. AMK B-12153 (15)
 9418551-P42 10-24X3/8 .44 Conical Glove Box Hinge 67/68 Phillips Head AMK B-10925 (3)
 9419028-P127
 9419107-P361 1/4-20X5/8 7/16AF .44 split Zinc AMK B-12303 (4)
 9419234-P319 washer .41 X .73 X .06thk B-11281 (12)
 9419301-P48 Hood Hinge to Hood but not Hood Hinge to Fender- 3/8-16X13/16 1" Conical AMK B-10835 (4)
 9419303-P52/72/187 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
 9419305-P92 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
 9419326-P163
 9419327-P's 43, 44 8-18X1/2 .31 O.D. AMK B-12152 (15)
 9419329-P167 10-16X5/8 .37 O.D. AMK B-11530 (10)
 9419328-P163 10-16X1/2 .37 O.D. AMK B-12192 (10)
 9419370-P70/89 5/16-18X5/8 1/2AF .55 split AMK B-12312 (4) Phosp B-12313 (4) Zinc
 9419380-P103/128/153 1/4-14X3/4 3/8AF .5 O.D. AMK B-11104 (25)
 9419400-P366 1/4-14X1/2 3/8AF .5 O.D. B-12093 (Cool B-11400 (25)
 9419402-P123 5/16-18X3/4 1/2AF .66 O.D. AMK B-12589 (6)
 9419663-P163 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate Same screw as 9415464 & 9426269
 9419672-same as 9419327
 9419778-P229
 9420151-P153 1/4-14X3/4 3/8AF .5 O.D. AMK B-12102 (Cool Phosp B-12103 (Cool Zinc 9420152 ¼-14X1/2 3/8 AF AMK N/A Obtained Corvette Central #192117 correct zinc “E” screws. Additional info last page.
 9420415-P38/150/155/156/178 1/4-14X3/8 3/8AF .5 O.D. AMK B-11097 (Cool B-11099 (25) Orig. head markings 'D' & RBW w/dimple (69 AIM pages-28, 155, 156, 161, 178, 182, 439, 440, 441, 460)
 9420431-P156 10-24X1/2 5/16AF .4 O.D. Similar AMK B-10411 (8 pcs.)
 9420494-P55
 9420554-P153 8-18X1.0 .27 O.D. AMK B-11120 (10)
 9420603-P62/113 5/16-18X3/4 1/2 AF .64 OD RBW (note-similar to 9780422 & used on Z-bar)
 9420686-P229 8-18X5/8 1/4AF .34 O.D. AMK B-11076 (10)
 9420721-P41 Same as 9423863 8-18X3/4 .31 O.D. Phillips Head Phosphate B-12170 (10) Zinc B-12171 (10)
 9420723-P42 AMK N/A
 9420825/3958062-Pages 72/73/123 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip AMK-Anchor B-10416 (4)
 9420941-Battery Tray- 5/16-18X5/8 1.12 Conical AMK B-13716 (2)
 9421137-P229 8-18x1/2 .31 O.D. AMK B-11144 (10)
 9421479 P37 Zinc-Cowl Panel Screw 8-18X9/16 1/4 AF .62 Flat AMK B-12172 (4) Our originals were phosphate, but not the norm.
 9421495-P46 10-16X1/2 .37 O.D. Outside Mirror AMK B-11223 (6)
 9421851-P41/167 10-16X5/8 .44 Flat Washer AMK B-12231 (6)
 9421934-P231
 9422245-P45 Listed under AMK but not on page shown???
 9422297-P320 Cad anchor nut 3/8-16 GR8 9/16 AF .33 thk AMK B-10526 (6)
 9422455-P230
 9422606-P72
 9422641-P128 1/4-14X1.0 3/8AF .75Flat Note: our 68 had 1.0 Flat vs. .75" AMK B-11431 (5)
 9422654-P41 Clip Nut #8 .44 X .62L AMK B12245 (Cool
 9423258-P161 10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9425622 same screw
 9423351-10-16X7/8 .31 O.D. AMK B-11138 (Cool
 9423863-Same as 9420721 8-18X3/4 .31 O.D. Phillips Head AMK Phosphate B-12170 (10), Zinc B-12171 (10) 9424858-P188
 9423909-P122
 9424858-P55 10-16X3/4 .37 O.D. Similar AMK B-11157 (10) phosp B-12197 (10) Zinc
 9425111-P42 AMK N/A
 9425486-P170
 9425578-P169
 9425622-10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9423258 same screw
 9425812-10-16X1 .36 O.D. AMK B-12226 (4)
 4926269- see 9419663- 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate
 9426539-10-16X3.0 .31 O.D. AMK B-11139 Note: Used for 67 Camaro vent window
 9427208-P44 Steering Arm Cover 67/68 8-32X7/16 .38 Conical AMK B-10848 (4)
 9427326-P53
 9428499-P229
 9431963-Zinc/Ign. Coil Bracket- 5/16-18X5/8 5/8 external AMK 'RBW' B-13232 (4)
 9432395-Trunk Latch/striker 1/4-20X5/8 .75 toothed AMK B-10891 (5)
 9780422-Pages 137/141-145, 149, 153 5/16-18X3/4 .67OD AMK 'anchor' B-13306 (12) B-13307 (50) Heavy use-fender, header, valance, batt. tray, hood catch, etc..
 9824833-Std. Arm-rest Base Screws 1/4-14X1 1/2 .45 OD AMK B-11163 (6)
 9919303-P138
 Door-Deluxe/Custom Door Pull Straps 68/69 Camaro 1/4-14X1 7/16 .37 O.D. AMK B-11161 (4)
 Door-Inside window hardware screws (correct) 1/4-20X7/16 7/16AF .55 O.D. AMK B-10427 (6)
 License Plate Screws- AMK B-11179 (Cool
 Seat Back Panel Screws 67-69 Camaro 8-18X3/4 .5 Flat washer AMK B-11222 (4)
 Tail-lamp Housing Screw 67/68 Camaro 8-18X1/2 1/4AF .34 O.D. AMK B-11075 (12)
 Wheel Opening Trim Screws- 8-18X7/16 AMK B-11532 (10) & B-10064 (32)
 Bolts
 0122017-P79
 0122104-P152
 0179868-P68
 0180122-P79 3/8-16X1.0 9/16AF AMK B-10148 (4) Phosp B-10149 (4) Zinc
 0180124-P79 3/8-16X1.25 9/16AF AMK B-10136 (4) Phosp B-10137 (4) Zinc
 0186622-P126 3/8-16X1.25 9/16AF AMK B-11616 (4)
 0191163-P79 3/8-16X4.0 9/16AF AMK B-10165 (1) Zinc
 0385099-P127 5/16-18X5/8 1/2AF .75 Conical Similar AMK B-12548 (5)
 0396712-P121 3/8-16X3.5 .8 O.D. AMK B-10074 (2) Note:thread end not correct
 0839756-Flywheel 7/16-20x1.0 11/16AF AMK B-10191 (3) 3758783-P Battery hold down bolt with .87Dia captured washer
 3790332-P62 5/16-18X6.5 9/16AF .34 Body Similar AMK B-10174 (2)
 3817224-P94 'A' head marking AMK kit G4650 like originals except for bolt end chamfer
 3892754-P66
 3929905-P178 chrome 3/8-16X2.0 .75 O.D. AMK B-12755 (2)
 6255899-P178/179 chrome 3/8-16X7/8 .75 O.D. AMK B-12751 (2) B-10887 (4)
 9417950-P178
 9418822-P81 See 180122 3/8-16X1.0 9/16AF
 9418967-P79 3/8-16X3/4 9/16AF AMK B-10163 (2) Phosp B-10164 (2) Zinc
 9419008-P103
 9419073-P95 7/16-14X1.0 5/8AF AMK B-13682 (4)
 9419101-P178 1/2-13X1.5 3/4AF AMK B-12590 (4)
 9419713-P127 7/16-14X3.875 5/8AF Similar AMK B-10186 (1) B-10187 (2)
 9421430-P59 1/2-13X3.75 3/4AF AMK B-13749 (2)
 9424069-Caliper Brake Brackets 7/16-14X1.25 5/8AF AMK B-10184 (2)
 9425299-P82
 Clips
 0125912-P73 Brake Line AMK B-10301 (4) cad. 3857706-P151 AMK N/A Heartbeat City has EGP-1124
 3880723-P161
 3881339-P73 Brake Line
 3886521-P73 Brake Line
 3886522-P73 Brake Line AMK B-10318 (1) Phosphate
 9422836-P161 AMK B-10588 (Cool
 Nuts
 0102646-P126 Tie Rod 7/16-20 5/8AF .38thk AMK B-10585 (2) Zinc
 0120368-P152 5/16-24 GR5 1/2AF .27thk AMK B-11505 (10) Phosphate B-12785 (10) Zinc
 0121743-P156 Alt/relay junction 12-24 7/16AF .16thk AMK B-10502
 0134530-P162
 0134551-P168
 0271172-P137/138 1/4-20 7/16AF .5 O.D. .24 OAH attached tooth washer B-12814 (Cool phosp B-13779 (Cool Zinc
 0272876-P67/94 Castle Nut 7/16-20 11/16AF .37THK AMK B-10045 (4)
 0359887-P118
 0381700-P51/55/56 push type spring nut 5/32 stud .44 O.D. AMK B-10566 (15)
 0445109-P163 spring nut #8-18 .41X.62 long AMK B-13370 (Cool
 0445347-P51
 1359889-P144
 1378333-P127 flange nut 3/8-16 9/16AF .89 O.D. .4 thick AMK B-10475 (6)
 3759924-P155 elect washer/nut 10-24 3/8AF .45 O.D..19 OAH AMK B-13507 (Cool
 3846854-P138
 3849974-P153 headlamp housing spring nut #14 AMK B-12259 (6)
 3899847-P153 headlamp bezel plastic nut AMK B-12914 (6)
 3907444-P178/179 Plastic Push in (license plate) AMK B-12920 (Cool
 3921446-P153 headlamp adjustment plastic push in AMK B-12923 (4)
 9417954-P178 5/16-18 GR5 1/2AF .27thk AMK B-12782 (10) phosphate B-12783 (10) Zinc
 9418302-P144
 9418828-P178 1/2-13 GR5 3/4AF .44thk AMK B-12797 (6)
 9418931-P48/59/70/113 3/8-16 GR5 9/16AF .33 thick AMK B-12788 (Cool Phosphate B-12789 (Cool Zinc
 9419751-P139
 9419753-P137/139 stamped nut 1/8 5/16AF .53 O.D. AMK B-10629 (10)
 9419755--P154 stamped nut #10 3/8AF .5 O.D. AMK B-13383 (10)
 9419841-P138 stamped nut 10-24 3/8AF .5 O.D. AMK B-10352 (10) Phosphate
 9419845-P52
 9420171-P166
 9420222-P153
 9422654-P153 spring nut #8 AMK B-12245 (Cool
 9425691-P178/179 conical nut 3/8-16 9/16AF 1.0 O.D. .46 OAH AMK B-12841 (4) B-11515 (12)
 Lock Washers/P-Washers
 0103319-P82/103
 0103320-P178
 0103321-P70/81 3/8 Regular lock washer
 0103328-P95 7/16 Heavy .45X77 X.14THK AMK B-13058 (20)
 0128144-P178
 0135629-P42
 0174916-P150 Toothed washer elect grounds 1/4 .26X.69 O.D. AMK B-11314 (Cool
 0187119-P82 lock washer 5/16
 1193463-P127 ,46X1.13X.19thk AMK B-11287 (3)
 1362249-P178 53X1.24X.12thk AMK B-13073 (4)
 3693853-P94 flat washer similar .47X.93X.09thk AMK B-11291 (12)
 9419892-P103 flat washer .28X.62X.07thk AMK B-12989 (20) Phosphate B-12990 (20) Zinc
 Rivets
 67/68 Grille & RS Mldg.3/16X.27LX.44O.D. Black Anodized Alum. AMK B-13426 (Cool
 9417761-P121 Drive Rivet to replace later service replacement gas cap screws. #6X5/16 .25 O.D. AMK B-10762 (10)
 Wing Nuts/Clip Nuts/Special
 0102634-P65 5/16-18 GR5 1/2AF .27THK AMK B-12782 (10) Phosphate B-12783 (10) Zinc
 0124829-P113/150 3/8-16 9/16AF .22THK AMK B-12787 (Cool Phosphate B-10504(Cool Zinc
 0273801-P89
 0358501-P65 Lug Nut 7/16-20 3/4 AF .56 OAH AMK B-10010 (5) B-01545 (20)
 0447143-P29 Detail #2 P Windshield Washer Nozzles AMK #B-11070 Zink Silver plating
 1361640-P94
 1365067-P68
 3743360-P113 Bell-crank Felt AMK B-11303 (1)
 3784845-P142/144 fender clip but nut not correct 5/16-18 .69WX1.0L AMK B-10616 (4)
 3829086-P117
 3841497-P319 Shifter linkage nut 7/16-20 9/16 AF .22Thk AMK B-10511 (4)
 3868790-P40 Firewall Mat/Pad Rubber Plug AMK B-10672 (2) Can purchase as kit also
 3886973-P39 washer nozzles
 3892755-P66
 3876130-P92 Volt. reg. 10-24 .37X.56L body .56 Flange O.D. AMK B12936 (3)
 3899880-P145 fan shroud clip AMK B-10720 (2) Note: similar
 3901399-P67 Springs & axle housing Nut 7/16-20 GR-8 11/16 AF .62 long AMK B-11508 (8)
 3916608-P132 Spare Tire J-hook AMK B11379 (1) Note: see 9785616 wing nut
 4874119-P37 Cowl Panel Plug
 7279805 Radio Shaft Nuts 7/16-20 9/16 AF .12 THK B-10556 (2)
 9417614-P66 1/2-20 GR8 3/4 AF .44 thk AMK B-10499 (4) Phosphate B-12801 (4) Zinc
 9418699-P102
 9419912-P103 Air Cleaner Nut 1/4-20 1.32 W AMIK B-10008 (1) Chrome
 9422297-P79/81 nut 3/8-16 GR8 9/16 AF .33 THK AMK B-10526 (6) Cad
 9422299-P59 nut 7/16-14 GR8 11/16 AF .38 THK AMK B-10533(4) Cad
 9422301-P59 nut 1/2-13 GR8 3/4 AF .44 THK AMK B-10518 (4) Cad
 9423518-P41
 9785616-P132 Spare Tire Wing Nut AMK B-10612 (1) Note: see 3916608 J hook
 CRG thread on hardware- Correct Fasteners and headmarkings
 Thread I started on CRG & 68 fasteners- Documenting 68 Camaro Fasteners & Hardware
 9420152-409 Radio Ground strap (68 AIM page 409) from body to sub-frame utilizes screw 9420152 and it was zinc. The screw is a self-tapping, 1/4-20 x 1/2", with indented head. Our originals were 'E' and can be purchased @corvette Central #192117 (2 for $2). Paragon offers the same screw with "RBW" #11189K, 7 screws for $5.00. 1967/8 Corvettes used this screw for radio ground straps and the front crossover brake line clip. AMK does not offer this screw!
« Reply #3 on: May 31, 2019, 12:18:05 AM »
steve's 68
« Reply #4 on: January 05, 2022, 12:19:35 AM »
Big thanks for all of the tips and information!  I am finally at the point of finishing up some things but am still stumped by the starter wire clip on the lower right (as viewed from the front) heater box cover stud.  I did go thru the AIM but have found a conflict.  Page I/M2 (page 52 in my book) shows a "J" clip, but sheet 12/A11 (page 158) shows a more complex configuration.  This clip was snugged up on my wire too far away to be installed on the stud and the configuration appears the same except it is a mirror image.  Additionally, my wire has been wrapped with what appears to be some type of heat insulating tape, is this original?  A photo would be great but any advice would be appreciated. Thanks in advance for your help
« Reply #5 on: January 05, 2022, 02:39:18 AM »
Going of Memory, The Insulated Wire "J" Clip associated with the Heater Box Stud is Used to route the Blower Orange wire outboard towards the Motor located up in the Fender on the firewall blower duct. Starter wire routing is via a different clip under a bellhousing to trans bolt at the rear of the block.
« Reply #6 on: January 05, 2022, 08:01:12 PM »
OH!
So
Page UPC1/M2 Sheet 52 Routing is for the Base ENg. L6/6Cyl configuration.
Page UPC12/A11 Sheet 158 Routing is for the Optional Eng, V8/8cyl configuration.
By your Initial Post and description you have a 68 SS (350 or 396) either Way your Clip (Was part of the Engine Assy) & routes per UPC12/A11 Sheet 158.
Guys am I tracking this right?
JIM
Gars68Tux
« Reply #7 on: January 06, 2022, 09:07:33 AM »
I'd say the J clip shown on pg  52  (68AIM) was used on both L6 and V8 base model (engine) cars. Probably SS and Z/28 as well ? The bellhousing clip shown on page 158 is unique and totally different than a J clip. I was thinking both clips were used for the starter motor harness...
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
x55cam
« Reply #8 on: January 09, 2022, 02:16:55 AM »
If it helps, my '68 327  used a j-clip
Be careful about reading  health books. Some fine day you'll die of a misprint. - Markus Herz
« Reply #9 on: January 09, 2022, 03:17:17 AM »
So Both L6/V8 use the UPC1 heater box clip, just the V8 harness needs routing thru the transmission clip to keep it off the V8 exhaust area for heat-damage protections.
Here is a snap shot of the clip called for UPC 12 /A11
Gars68Tux
« Reply #10 on: January 09, 2022, 05:16:13 AM »
Good photos. There's another shot of the bellhousing clip in this thread from TC...https://www.camaros.net/threads/where-does-this-go.481710/#post-1783280838
Garth
steve's 68
« Reply #11 on: January 11, 2022, 11:44:13 PM »
Great photo, my clip is similar to that one but the 'wire clip' configuration portion is different.  Guess I will put it in in a way that it keeps the wire away form the exhaust manifold.
Thanks to all for your help!
« Reply #12 on: January 12, 2022, 01:35:17 AM »
My EARLY 69 Z had this clip for the starter wires.
steve's 68
« Reply #13 on: January 15, 2022, 08:03:26 PM »
Thanks again, there seems to be photo evidence of both types of clips and inside or outside the heater hoses, could this be a "where built" situation?  My 68 is an NOR.
