Author Topic: 7029204 FF carburetor  (Read 3869 times)
Danzo
« on: August 17, 2018, 10:33:35 PM »
How common/rare is it to have an undated carb? Have the above listed number off an 03D 396/325hp Camaro.
Thanks, Doc
Re: 7029204 FF carburetor
« Reply #1 on: August 17, 2018, 10:42:39 PM »
From the CRG carburator report...
The date code was stamped either on the base of the carburetor toward the rear on the driver's side of the car, or on the vertical boss next to the identification number. The date will be in a four-digit format (where the first three numbers are the Julian day and the last number being the year).
Did you check both locations??
Link to full report...
http://www.camaros.org/carb.shtml
Danzo
« Reply #2 on: August 18, 2018, 10:39:35 AM »
I did which is why I am asking.
« Reply #3 on: August 18, 2018, 12:20:01 PM »
Could be a service replacement.
« Reply #4 on: August 18, 2018, 02:43:11 PM »
After 50 years, it's probably been rebuilt several times and the base plate has been replaced. I've seen this a lot over the years. Not much you can do about it now.
