Author Topic: Convertible top differences  (Read 10275 times)
67CruiseMaster
« on: May 27, 2018, 11:44:13 PM »
Guys other than the rear portion of the convertible top differences, is there anything different at the front? Like the matches or the part that fits to the top of the windshield?
67 Tuxedo Black Convertible.
Re: Convertible top differences
« Reply #1 on: June 01, 2018, 05:18:56 AM »
Huh? Differences between what?
Petes L48
« Reply #2 on: June 01, 2018, 11:49:03 AM »
Are you asking about the top frame - power versus manual?
67CruiseMaster
« Reply #3 on: June 01, 2018, 07:14:21 PM »
Yes Pete. Is the front bow between manual and power top the same? Are the front latches same too?
Mark
« Reply #4 on: June 01, 2018, 09:07:10 PM »
Yes the front bow is the same, the hinge between the front rail and the one over the quarter windows is different (which probably makes the entire front side rail different as the hinge is welded to one or the other rail), and the operating arms that push and pull the top up and down are different.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Petes L48
« Reply #5 on: June 01, 2018, 09:09:55 PM »
I can't find the old discussions here or at the TC site on this, but I believe the only difference is the rear side frame sections, where the power top is more beefed up.  Heres' a Firebird discussion which is probably the same:
https://firstgenfirebird.org/f-a-q/manual-vs-power-top-parts/
The top is found in the Body by Fisher Service Manual, but I don't know if it details the differences.
67CruiseMaster
« Reply #6 on: June 01, 2018, 11:58:32 PM »
Thanks Mark and Pete. Just as I suspected. I knew the rear section was going to be different. Read some threads where someone put a motor on a manual top and it damaged the frame on the manual top. Good to know about the front bow. I suspect latches are same too.
KevinW
« Reply #7 on: June 02, 2018, 12:01:21 PM »
Here is the only top frame difference, the middle welded hinges over the doors, power on left, manual on right.  Rest of frame is the same and can unbolted.  But this hinge is welded to the two side pieces.
68L30
« Reply #8 on: June 03, 2018, 08:17:56 PM »
Are you in need of a power frame or parts?
67CruiseMaster
« Reply #9 on: June 03, 2018, 08:26:41 PM »
im currently looking for a power frame yes.
68L30
« Reply #10 on: June 04, 2018, 01:57:20 AM »
I may be able to help!
Norwood#27906
« Reply #11 on: September 24, 2018, 10:34:56 PM »
Does anyone have clear close-up images of the power frame linkages and attachment points?
68L30
« Reply #12 on: September 26, 2018, 01:17:07 AM »
I have a entire top frame out in the open...minus the hyd cylinders. What shots do you need?
Norwood#27906
« Reply #13 on: September 28, 2018, 01:06:08 AM »
IF you could, a couple close ones along the top of the first hinge similar to the side view that KevinW posted above. I'm interested in the attachment points and general shapes of the three short links. I'll be glad to share whatever I learn. Thanks!
