Author Topic: Glass Norwood Los Angeles  (Read 10592 times)
x66 714
« on: March 01, 2018, 12:50:30 AM »
Would there be a chance that a Norwood car might have glass from the Los Angeles glass plant, ie. glass ending in "10"? Referring to a late 1969 built car.
Thank you, Joe
Re: Glass Norwood Los Angeles
« Reply #1 on: March 01, 2018, 05:00:52 AM »
Can you explain your question a bit more?  ie..  that 'code ending in 10' ???    I'm unaware that the glass was coded for the plant installing it....?
« Reply #2 on: March 01, 2018, 07:15:12 AM »
I think if you read the CRG glass dating page, in early 69 (January) each glass plant would also etch a code for the plant that produced the glass.
10 = Lathrop CA.
http://www.camaros.org/glass.shtml
x66 714
« Reply #3 on: March 01, 2018, 11:28:32 AM »
It wasn't the plant that installed the glass. It was the plant that manufactured the glass. My quarters & back window are "IV" & my RH door is "TV10". The TV10 glass was made at the LA glass plant & my car was built in Norwood on Aug 28, 1969 so all those dates work. I've questioned the door glass. Last night I ran into another guy who has TV10 glass in his 09D Norwood car. After reading the article Austin posted, I'm thinking both cars could be correct.....Joe
« Reply #4 on: March 01, 2018, 04:02:39 PM »
10 = Lathrop CA.
Not entirely correct; maybe you missed this part..  :)
 "...The "-xx" suffix on the LOF date code is the plant code. "-10" indicates the source was the Plant 10 Lathrope, CA LOF facility that supplied primarily the Van Nuys, CA Camaro assembly line. A "blank" code (no plant code) was used by Plant 8 that supplied all windshields to both Camaro factories, as well as tempered glass primarily to the Norwood, OH assembly line. "
I've never seen a glass date with a 'glass plant' code (on my '50s - 60's cars), but then we don't see too many VN/LA produced cars here, which is why I asked the question about the '10' referenced in an earlier post...  :)    Oh..  and the CRG glass section I believe has been updated fairly recently (since I read it)...
Kelley W King
« Reply #5 on: March 01, 2018, 04:32:19 PM »
My 08E Nor car has TV10 glass.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
x66 714
« Reply #6 on: March 01, 2018, 05:45:49 PM »
Kelley. Does yours have TV10 on all glass or does it follow the same as mine? Your car was built the same day as mine. Thank you, Joe
Kelley W King
« Reply #7 on: March 01, 2018, 06:44:02 PM »
If I remember correctly TV10 was passenger side rear glass I think. I wrote it down but it is at my home shop.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
x66 714
« Reply #8 on: March 01, 2018, 09:47:29 PM »
Kelley. Could you maybe take a look when you get home please? Thank you, Joe
Kelley W King
« Reply #9 on: March 02, 2018, 02:27:06 PM »
Did not get to it yesterday. I will post all the glass dates this weekend.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
« Reply #10 on: March 02, 2018, 10:34:52 PM »
The CRG glass report says Lathrope primarily supplied Van Nuys, so presumably it could also have supplied other assembly plants.
x66 714
« Reply #11 on: March 04, 2018, 02:28:45 AM »
That would be great. Thanks again Kelley....Joe
« Reply #12 on: March 05, 2018, 05:29:08 AM »
It's mostly the Aug 69 cars. I had one (08E) with XV-10 on the right 1/4. All the other glass was 'normal'.
Kelley W King
« Reply #13 on: March 05, 2018, 12:24:21 PM »
Finally checked my 08E car. All glass has IV except the passenger door glass TV 10. Front and rear not original. All are Soft Ray LOF. I think Austin,s car is the same.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
x66 714
« Reply #14 on: March 05, 2018, 02:17:48 PM »
Thank you for taking the time to look Kelley.....Joe
