Author Topic: Protect-o-plate number ?  (Read 11922 times)
cfar
  • L30/M35 Tuxedo Black
« on: January 26, 2007, 04:08:25 PM »
11C -68 L30/M35  LA Car
I am trying to decode my protect o plate
On the bottom right side is the rear code-
PA1108G
PA ios 308 ratio
what is 1108G ?
Also under that is 133 1 2
what are these numbers?
The far right  horizontally is a  C  (is that carter carb)
                                         N  (is this buld month)
Frank
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
Re: Protect-o-plate number ?
« Reply #1 on: January 26, 2007, 04:15:46 PM »
Frank,
The 1108G is the date the axle was assembled and the plant that did it. In this cse, your axle was assembled on November 8th, 1967 at the Detroit Gear and Axle Plant (1st shift).
The 133 1 2 are option codes and they're in a specific order. Can you post a picture of the tag so we can take a look at it? That's the easiest way to decypher them.
Yes, the "C" would be a Carter carburetor and the "N" is is for the Build Date. November, 1967 in your case.
cfar
« Reply #2 on: January 26, 2007, 07:12:44 PM »
Ok Ed
here a thumbnail view to click on
Also on the trim tag far right top line above the BDY number is - J330
What is J330
 BDY code -is that the seqence code - 12921
thanks again
Frank
« Reply #3 on: January 26, 2007, 07:36:26 PM »
Frank,
Here you go:
1 - N40 Power Steering
3 - Unverified at this time, but it appears it's either B37 Color-Keyed Front and Rear Floor Mats, or B93 Door Edge Guards
3 - U63 AM Push Button Radio
space
1 - C60 Air Conditioning
space
2 - A67 Folding Rear Seat
Do you have these on the car?
The J330 is the Los Angeles Fisher Body plant internal scheduling sequence. Your car was the 330th car started on the J day (10th production day) of November, 1967. Your car was probably started on or around Thursday, the 14th of November, late in the day.
« Last Edit: January 26, 2007, 08:16:43 PM by bertfam »
cfar
« Reply #4 on: January 26, 2007, 11:23:50 PM »
Hi Ed,
Yes I have P/S and A/C  and fold down seat.
The car did have a radio but was updated with a custom autosound unit  so i will find a replacement for it.
Do not know on the mats or edge guards but based on the dealer installed door guards I removed(that were rivited on like they did in that era) it probably was the edge guards
thanks for the reasearch-I hope i can help others here also.
This place is great!
Frank
cfar
« Reply #5 on: January 26, 2007, 11:33:08 PM »
On the trim tag the BDY code is - 12921
Is this also a sequence code for assembly
thanks
« Reply #6 on: January 26, 2007, 11:56:59 PM »
Yes, that's the Fisher body sequence number.
westonz28
« Reply #7 on: January 27, 2007, 03:04:25 AM »
Just a question on the unused code. Does your Camaro have the fiber optic or the light monitoring system (U46) on the fenders? I also have the same code on my POP but do not have the door molding or floor mats, granted the floor mats could have been trashed years ago. Could this code could be for punching the holes in the fenders, as they were punched not cut out? As floor mats and door molding were very common and the 3 code is very rare on the POP maybe this is what it was for.  Thank you for the responce.
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
cfar
« Reply #8 on: January 29, 2007, 02:24:53 AM »
No it does not any never did have the hole in the OE fenders on car now.
Start a post on it to see who knows
Frank
