Author Topic: Pulley diameters - anyone have these pulleys  (Read 15178 times)
« on: March 21, 2017, 08:40:03 PM »
Can you help with this pulley list?
Here is a list of first gen pulleys that we don't have the diameter (list is also on-site). The alternator pulleys don't always have numbers stamped on them so it would have to come from an known original part.
Diameter is simply the OD of the part. (Originally, they would have been measured over steel balls because you care where the belt sits, not the OD.)  Sorry about the column alignment, took work to even get it this nice!
SB is small block, BB is big block, DG is deep groove.
Pulley #   Application     Notes        Year
1969433   Alternator     L6, K76     68
3744043   Crank           SB             67, 68
3755820   Crank           SB     67
3770245   Water pump   DG, Z/28   67, 68
3790337   Crank ext for ps   L6     69
3844100   Alternator      DG, BB   67
3850156   Alternator      L6, 3843346 fan used   67
3853104   Crank ext for ps   L6 with A/C   67
3853400   Crank ext for ps   230 cu in   67
3860457   Power steering         67, 68
3863108   Crank           BB, DG, cast iron   67
3869978   Crank           DG, cast iron   67, 68
3871253   Alternator     L6, cast iron, 3843346 fan used   67
3874412   Crank           BB     67
3874416   Crank ext for ps   BB     67
3876846   Water pump         68
3876872   Crank ext for ps   L6     67, 68, 69
3880886   Power steering    L6     68, 69
3890419   Water pump        67, 68
3909815   Alternator      Fan and pulley are one piece   67
3909817   Alternator                67
3916385   Crank ext for ps   DG, Z/28   67, 68
3921923   Crank           DG, BB   68
3927789   Water pump  L6 with A/C   69
3932498   Crank           w/ PS, unverified usage   69
3937788   Crank           BB, unverified usage   69
3941105   Power steering   DG     69
3947824   Water pump  DG, BB   69
3955290   Crank           BB     69
3955291   Crank           DG, BB   69
3956664   Crank                69
Thanks!
Kurt
HawkX66
Re: Pulley diameters - anyone have these pulleys
« Reply #1 on: March 22, 2017, 12:11:59 PM »
I have a couple of those BB 69 pulleys on my original 396 Kurt. I'll try to grab some measurements for you tonight. My water pump pulley isn't on your list though. Do you want that? 3932402 UD
Water Pump
Crank Pulley
3955290 AD
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: March 22, 2017, 03:26:57 PM »
Do you want them measured with a tape, or with a calipers? So with a tape it might look like 6 3/4", but it might measure 6.80" with a calipers.
Jimmy V.
« Reply #3 on: March 22, 2017, 04:07:45 PM »
Calipers would be preferred and more accurate, but tape is fine.
Most pulleys already have a diameter noted - http://www.camaros.org/engine.shtml#PulleySpreadsheet. Just trying to complete the table. :)
Thanks!
stovebolt
  • 1968 L6 Sport Coupe
« Reply #4 on: March 22, 2017, 09:12:14 PM »
1969433. I bought this NOS pulley for my 1968 L6 Sport Coupe. There are no markings on the pulley. The O.D. is 2.25".
« Reply #5 on: March 22, 2017, 11:36:42 PM »
3770245 Water pump DG, Z/28  67, 68 ≈ 7.1 (≈ 7-3/32" with tape measure) code CC
3916385 Crank ext for ps DG, Z/28  67, 68 ≈ 6.7 (≈ 6-11/16" with tape measure) code CD
« Reply #6 on: March 23, 2017, 06:43:35 AM »
Stovebolt,
That's one that I didn't think we would ever get the dimensions!
Paul & Stove,
Thanks!
jdv69z
  • 69 RS Z/28 52E
« Reply #7 on: March 23, 2017, 01:50:31 PM »
I've measured my 69 Z power steering pulley at 5.75" I can't verify it's the part number you listed, but it should be. I've attached a pic. Does it look like the correct one?
Jimmy V.
« Reply #8 on: March 23, 2017, 05:16:39 PM »
Thanks, it looks correct.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #9 on: March 23, 2017, 09:18:58 PM »
3956664                   69
 1969 SB Base V8; CF code
6-3/4" OD, by tape
Richard Thomas
1969 RS
rich69rs
  • LF7/M35/Z22/Z87
« Reply #10 on: March 23, 2017, 09:19:34 PM »
3956664            69
6-3/4" OD, by tape
Richard Thomas
1969 RS
« Reply #11 on: March 24, 2017, 12:07:35 AM »
Slowly knocking them off the list. Thanks!
Marty
« Reply #12 on: March 24, 2017, 03:22:38 AM »
I have several on the list but no time to get to them right now. I might have notes on some too. Will post when I have time.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
HawkX66
« Reply #13 on: March 24, 2017, 04:54:00 PM »
Crank Pulley
3955290 AD
6.75" measuring tape
Dave
Semper Fi!
plumL78
« Reply #14 on: March 27, 2017, 07:28:23 PM »
3844100 alternator pulley is 3.218
