Author Topic: Disc brake proportioning valve  (Read 5858 times)
Terry69RSZ28
« on: November 03, 2016, 03:39:06 AM »
Hi Everyone,
Do 69 disc brake proportioning valves have any numbers or date codes on them?
Thanks for your expertise, Terry
Re: Disc brake proportioning valve
« Reply #1 on: November 03, 2016, 04:06:57 AM »
Yes, see photo...  I believe the date code is encoded as:   julian date - Yr .. (mine is '154 - 9')  for the 154th day of 1969...  Also  'K-H' for Kelsey Hayes  and an 'R' for ...??.. rear?
« Reply #2 on: November 03, 2016, 04:59:42 AM »
great pic Gary. Now you just gave me something to want to look at next time I am in front of my own..... :D
« Reply #3 on: November 03, 2016, 09:23:39 AM »
Great article on brake valves right here: http://www.camaros.org/brakevalve.shtml
Terry69RSZ28
« Reply #4 on: November 03, 2016, 01:50:17 PM »
Thank you very much for clarifying my question!
Much appreciated, Terry
« Reply #5 on: November 03, 2016, 01:50:40 PM »
Absolutely ZLP...  JohnZ's article is great and I refer to it often myself.   (I should have remembered to refer to that in answering the OP's question)...  :)
jdv69z
  • 69 RS Z/28 52E
« Reply #6 on: November 03, 2016, 08:29:05 PM »
So I have a question regarding the distribution block that turns the brake light on if there is a pressure differential between the 2 sides. Can this only occur when the brakes are applied? That is, can there be a pressure differential when the brake pedal is not being depressed? My brake light stays on whenever the distribution block wire is connected, and the ignition is on.. And I know that wire goes to ground. As if the internal spool which moves is permanently stuck somehow or touching gound?
Jimmy V.
« Reply #7 on: November 04, 2016, 02:49:40 AM »
Can't answer your question Jimmy, but if it turns out your switch needs a rebuild, here's a great tech procedure from Muscle Car Research: https://www.musclecarresearch.com/gm-3956727-rebuild
jdv69z
  • 69 RS Z/28 52E
« Reply #8 on: November 04, 2016, 02:34:09 PM »
Thanks, I appreciate the info!!  :D
Jimmy V.
