Author Topic: Headers that fit?  (Read 13842 times)
jdv69z
  • 69 RS Z/28 52E
Re: Headers that fit?
« Reply #15 on: August 30, 2016, 02:53:26 PM »
Hope these help. Note that #6 is the toughest plug to get at. I use a shorty 13/16" wrench to tighten/loosen it. Then my fingers. The plug wire comes pretty close to the header on that cylinder as well.
Jimmy V.
« Reply #16 on: August 30, 2016, 06:32:51 PM »
Great pics.
They could be up a little bit more, but they did a nice job, esp compare to the crap that is out there....
The Tri-Y design is one reason they clear more components (overall less tubing and no area where all 4 tubes come together).   I thought I recalled that a Tri-Y design also helps torque, but my 'old memory' isn't as trustworthy any more.. :)..  so I consulted google and found a Hot Rod Mag article on 'selecting the right header', and the pros of Tri Y headers are listed as:  "Tri-Y Long-Tube: Tri-Y headers came to popularity when they were used by Shelby for the GT350 Mustangs. The tri-Y design combines a short primary that is paired with another cylinder that is synchronized in the firing order into a 2-into-1 collector that steps to a larger diameter secondary tube. The two secondary tubes are then merged into a final 2-into-1 collector creating an overall length similar to a 4-into-1 design. The traditional design works well to build more torque from idle to 4,500-5,000 rpm, so they are very effective for street use, however, autocrossers and road racers also love them for their midrange torque and increased throttle response as well. NASCAR teams use a derivative design, called a 4-into-2-into-1 (4:2:1), which uses much longer primary and secondary tubes for higher-rpm effectiveness."
Full article here:   http://www.hotrod.com/articles/how-to-pick-the-right-header/
JKZ27
« Reply #17 on: August 31, 2016, 01:13:48 PM »
Yes. All great pics. Thank you.
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #18 on: September 03, 2016, 10:44:06 AM »
Hooker Super Comps fit in a 68 with a 406, Dart aluminum heads and manual steering box without much fuss.
« Reply #19 on: September 03, 2016, 12:07:45 PM »
What about the back drive????
« Reply #20 on: September 03, 2016, 02:35:34 PM »
Not exactly sure what you mean. Has a Lakewood bellhousing and Muncie. Custom bent 2.5 inch exhaust with H pipe. This is in dad's car.
« Reply #21 on: September 03, 2016, 02:52:19 PM »
67 & 8 do not have the back drive (reverse lockout) linkage like the 9s..  Completely different  steering columns..
« Reply #22 on: September 03, 2016, 03:35:13 PM »
Had a brain freeze there for a bit.
Aftermarket Hurst shifter, tilt column. Reverse lockout, nope. Unless it helps the car go fast, it's not on the car! :)
