Author Topic: Headers that fit?  (Read 13817 times)
X33RS
Headers that fit?
« on: August 28, 2016, 03:17:38 PM »
I'm not good at searching but so far I haven't found anything that answers the question.   I've talked to a couple manufactures and they tell me either the back drive linkage has to be removed or I hear it doesn't clear a power steering box.  Google searches come up with all kinds of different answers that don't appear to be certain.  No pics, no feedback, etc..
  Is there a header that works without fuss?  Without removing reverse linkage?  I'm finding it hard to believe as popular as these cars are, there isn't a header that fits the intended application with factory equipment in place.
Thanks for any insight.
Re: Headers that fit?
« Reply #1 on: August 28, 2016, 06:26:50 PM »
do a search on the CRG, seems like I have seen a discussion on this in the past. I think the one Jerry M recommended cleared everything but, was quite pricey. hope I am remembering right.
BillOhio
    • photobucket
« Reply #2 on: August 28, 2016, 07:23:58 PM »
1968 RS 327 4 speed
X33RS
« Reply #3 on: August 28, 2016, 11:12:49 PM »
Thanks Bill.  I did see that, and it is the most thorough discussion on them I've found yet.  But it still  seems to have skipped some key details that leaves unanswered questions.
It starts out with Doug headers that are supposed to work, then Gary mentions that Summit has them but no part numbers given and I've yet to find them there.  States they are made in 1 5/8 and 1 3/4.  I prefer 1 5/8 and it would be easier to package anyway.  Odd they are so hard to find a set that works with stock equipment.
  Later it's mentioned that Hooker headers work but no part number given.  There are at least 3 part numbers I've found for Hooker sbc Camaro headers, and they all have a disclaimer about back drive linkage.  Don't know which hookers they are talking about  ???.
So yeah, the answers I've found seem to be all over the place with nothing definite.  If worse comes to worse, I'll buy some cheap headers and start cutting/welding tubes.  Just seems I shouldn't have to do that for the most popular car in the world, lol.
X33RS
« Reply #4 on: August 28, 2016, 11:26:06 PM »
Bill,  Okay it did help.  Your post made me go back and search for Dougs headers again.  I guess it helps if you type it in correctly  ::)  Stupid computers, lol
I did find Dougs for $639 coated in 1 5/8 tube.  according to reviews they are said to clear, clutch, PS, and back drive linkage.  Part number DOU-D308
They are also offered in 1 3/4 tube with similar reviews.
I'll be buying a set of Dougs and trying them out.
jdv69z
  • 69 RS Z/28 52E
« Reply #5 on: August 29, 2016, 12:28:17 AM »
I have the Doug's 1 5/8" Tri-Y headers on my Z, and they work no problem with the back drive linkage. I'm installing the new Hurst shifter at present, and I'll post a pic as soon as I've got it together. Years ago I had installed the Hooker Comp headers (not the Super Comp) which did interfere with the back drive linkage. So I took the original bell crank (the part mounted to the frame which pivots to move the 2 rods)  to work and had them fab me duplicate. Then I had to heat up the duplicate part I made and bend about a 1" offset into it. It then worked with the Hookers. So, it is doable.
In the case of the Hookers, at least, they make one header which fits multiple cars, not just the Camaro. That's probably why they aren't set up as ideally as they might be if they were Camaro only.
Jimmy V.
« Reply #6 on: August 29, 2016, 03:01:18 AM »
D308 sound like the right part number. I think it was stamped on the flange. Ouch on the price - at least they are coated.
Jimmy,
Can you post a pic of the ground clearance of the collector?
« Reply #7 on: August 29, 2016, 12:37:12 PM »
AND...  Free Shipping from Summit...  :)
https://www.summitracing.com/parts/dou-d308
I've always had headers on my car.  The ones on it when I purchased it finally 'rotted', and I purchased coated Hedmans, but they interfered with the back drive, and they also 'touched' the floor on one side, so I never ran them.   Currently I'm undecided how to put the car back together, as I have *perfect* original exhaust manifolds (stored since removed when new on a friend's Z28), and I've purchased an original smog system for returning my car to totally original condition ... but..  these Doug's headers are very attractive to me... :)
jdv69z
  • 69 RS Z/28 52E
« Reply #8 on: August 29, 2016, 01:05:59 PM »
This help? Collectors are not much lower than the sub frame. Note that the shifter mechanism is removed in these photos.
Jimmy V.
jdv69z
  • 69 RS Z/28 52E
« Reply #9 on: August 29, 2016, 01:09:40 PM »
Another view
Jimmy V.
« Reply #10 on: August 29, 2016, 05:22:23 PM »
those tuck under the car very nicely. Thanks for posting Jimmy.
X33RS
« Reply #11 on: August 29, 2016, 10:46:41 PM »
Jimmy, as far as headers and ground clearance goes, I think what you have is as good as it gets.  Very few headers out there tuck up that nicely.   With a dozen cars in the stable, most have headers from various brands and nothing is that tight under any of the cars.
$630 for coated headers that fit that nicely is well worth the money.  I've spent $800 on headers that don't fit that good on a BBC application here.
Ground clearance is a concern on the Z because these things sit so darn low to begin with.  Great pics.
« Reply #12 on: August 30, 2016, 01:59:42 AM »
Great pics.
They could be up a little bit more, but they did a nice job, esp compare to the crap that is out there....
jdv69z
  • 69 RS Z/28 52E
« Reply #13 on: August 30, 2016, 01:01:03 PM »
And to think I bought them because of the Tri-Y design! ;D
Jimmy V.
JKZ27
« Reply #14 on: August 30, 2016, 02:27:17 PM »
Jimmy, could you post a pic of the flanges at the heads showing spark plug and wire clearance, if you get a chance? Thanks.
John
68 RS Ash/Ivy Gold 327EFI M20
