Author Topic: Will this fit?  (Read 11645 times)
TStone
  • 1968 Droptop #'s Matching - 327
Will this fit?
« on: January 03, 2007, 04:33:02 PM »
I have a 68 - can I fit 245/60/15's on the front using a stock 15/7 ralley wheel?
Thanx T
Classics only cost alot if you keep track of what you spend. :)
5th Annual Michigan FBody Association Meet & Greet 2009
-= Meet & Greet Official Forum =-
- [url="http://www.mifbody.com/vbullet
My68SS
Re: Will this fit?
« Reply #1 on: January 03, 2007, 05:25:05 PM »
I had 235/60/15's on the front of mine and they tended to rub a bit on full lock especially with bumps. At 245 width you would want to be down to a 50 profile - imo
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
sam
Re: Will this fit?
« Reply #2 on: January 03, 2007, 05:35:31 PM »
215/70R15 BF's fit great on my 69 with the Rally wheels up front. 69's are harder on fit than the 67-68's in my opinion. And the wheel well opening looks good to. Fills it up nicely.
TStone
Re: Will this fit?
« Reply #3 on: January 03, 2007, 05:48:04 PM »
where were they rubbing?
lakeholme
  • 68-12D L30/M35
Re: Will this fit?
« Reply #4 on: January 04, 2007, 12:54:16 AM »
67 and 68 wheel wells are not as condusive to over sized tires as 69 and later --different design.
I've got them (15 x 7) on my 68 (from previous owner --a new set of tires and yes, I'm too cheap to not run them!).  They will work, but they will also bump and rub --even with a firm ride (mine does).
Where do they rub?  Obviously, in a full turn of the wheel, but also over bumps running straight.  And this is different from bottoming out. The actual rub on mine is more on the outside of the wheel and wheel well.  It's actually more of a scrape.  So far --after about 3000 miles-- no noticeable damage to tire or wheel well.
Yes, they do look great --if that's your preference.  But they don't look original.
Take a look at this thread and the other thread(s) it refers to:
http://www.camaros.org/forum/index.php?topic=1346.msg7824#msg7824
TStone
Re: Will this fit?
« Reply #5 on: January 04, 2007, 02:05:46 AM »
What size tires are you running?
My68SS
Re: Will this fit?
« Reply #6 on: January 04, 2007, 11:12:10 AM »
As per Lakeholme, the outer edge of the tyre contacts the lip of the fender arch when turning.
Worst problems occur when it's the inside turning wheel, [i.e. left wheel when turning left] that makes the contact. Can start bending the edge of the guard and chrome mould down.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
lakeholme
  • 68-12D L30/M35
Re: Will this fit?
« Reply #7 on: January 04, 2007, 02:08:36 PM »
Front = 235/60/15
Rear = 255/60/15
About a year ago, my mechanic's assistant rotated front to back without asking or looking. (He was trying to be helpful.) I knew before I got the car backed out of the stall. 235/60/15 fills up the front well.
Like I said, I felt the scraping, but I haven't had the problem My68SS is describing... yet.
« Last Edit: January 04, 2007, 09:59:42 PM by lakeholme »
TStone
Re: Will this fit?
« Reply #8 on: January 04, 2007, 03:17:01 PM »
thanx for the info - starting to look like i'm getting new tires
