Author Topic: Rear End Ring Gear Decode  (Read 4849 times)
jdv69z
  • 69 RS Z/28 52E
« on: June 09, 2016, 06:48:38 PM »
Question regarding decoding of the numbers on the ring gear of my original 3:73 posi, BU code rear end:
Codes as follows:  2   GM   3862525    11 41    9  68
I decode as follows:
2  = Production Plant?
GM = General Motors
3862525 = Chevrolet Part No.
11  41 = 3:73 Ring and Pinion Set
9  68 = Sept 68 production
Does the "2" indicate a production plant, and if so, which one?
Jimmy V.
Re: Rear End Ring Gear Decode
« Reply #1 on: June 09, 2016, 10:24:20 PM »
It appears you got the most important stuff JDV... :)
« Reply #2 on: June 09, 2016, 11:11:33 PM »
I will look on some of the gears that I have. But I think the 2 is not significant.
