Author Topic: 1967 rear brake drums  (Read 4358 times)
67stripper
« on: May 27, 2016, 01:34:01 AM »
I have a 1967 Convertible 11B NOR build with casting 3841177 rear drums that I believe are original to the car. Amazingly one of the drums has only been turned 0.020 while the other has been turned 0.080. I'd like to get another brake drum to replace the 0.080 turned one. A friend has a couple of brake drums supposedly off a 1969 Camaro with casting 3993560. Are these the same? I haven't looked at them myself but in pictures I've found it looks like the 3993560 is the same but has the max dia cast as 9.590. The 3841177 do not have a max dia cast in them. Anybody have any comments about the difference in these brake drums or brake drums in general and how this difference in size (0.020 vs 0.080) might affect braking?
Re: 1967 rear brake drums
« Reply #1 on: May 27, 2016, 12:31:43 PM »
Aside from the cast markings the drums are the same.  Meaning they will work on any 10 or 12 bolt axle.  The difference in how much one is turned versus the other does not matter as long as you adjust the brakes to be equal on both sides.  Many drums and rotors for that matter are not the same thicknesses but as long as they are above the min thickness they should and would be fine.
