Author Topic: 1969 Z28 Flywheel  (Read 7144 times)
jeremywrags
1969 Z28 Flywheel
« on: March 08, 2016, 05:16:32 PM »
Hi All,
I am in the process or refreshing my motor and I have a couple parts that don't look right. 1st the balancer is wrong (not 7708), it's 8" tall but 1 3/4" wide so it's rubbing the sway bar. 2nd is the flywheel, Part number casting is 3973455 N  then J53 is also cast and finally GM2. My car is a January 1969 car but I can't seem to find any details on the right flywheel.
Anyone familiar with what the 69 flywheel should be and if mine is not right what it could be?
Re: 1969 Z28 Flywheel
« Reply #1 on: March 08, 2016, 05:29:22 PM »
The correct casting number for a '69 Z28 flywheel is 3791021.
jeremywrags
« Reply #2 on: March 08, 2016, 05:54:26 PM »
Thank you.
Any Idea what I have? I came across a few threads stating that these are identical in every way and asking weather or not they could have been used on a Z from the factory. Is the 3791021 the only possible option?
« Reply #3 on: March 08, 2016, 06:25:07 PM »
Thank you.
I'm sure there are replacement flywheels available for the 302, but the 3791021 flywheel is the one they came with from the factory.
3973455 flywheel search results...
http://www.corvetteforum.com/forums/c1-and-c2-corvettes/1829727-i-have-a-flywheel-3973455-n.html
http://www.camaros.net/forums/15-tag-team/191729-fly-wheel-application.html
« Reply #4 on: March 08, 2016, 07:51:53 PM »
If the balancer is rubbing the sway bar you most likely have 307/327 motor mounts on 302/350 frame brackets. That's a mis-match; the engine is incorrectly positioned too low in the chassis.
