Author Topic: 1969 radiator tag and clips  (Read 3207 times)
john302
« on: February 09, 2016, 12:01:14 AM »
Does anyone know if the id tag and fan shroud clips were installed before the radiator was painted?In the past I put the clips on after paint and painted the tag with the radiator.Black phosphate the shroud clips and outlined the code on the tag with white paint.Any thoughts on this?thanks John
Re: 1969 radiator tag and clips
« Reply #1 on: February 09, 2016, 01:40:53 AM »
I'm pretty sure I've seen a radiator or two with the tags (inadvertantly) soldered on. Which makes sense since the tag is the instruction sheet for building the radiator.
That should answer your question. :)
john302
« Reply #2 on: February 28, 2016, 09:03:13 PM »
thanks Kurt .So you would think the fan shroud clips would be put on before paint also?thanks John
