Author Topic: 1st gen wireing harness  (Read 5010 times)
Baconcks
« on: December 14, 2015, 04:28:11 AM »
So I just reinstalled my sub frame in my RS SS BIG BLK and I'm looking forward to putting the car back together from a rotisserie restoration. I'm restoring this car for value and want to try to keep everything original as possible . The car had huge rust issues and leaked so bad the previous owner quite driving it during the winter. Do you experts thing reinstalling a 47 year old harness is worth the hassle or will a new harness devalue the car. Thanks for you help
Re: 1st gen wireing harness
« Reply #1 on: December 14, 2015, 05:29:47 AM »
 You have to evaluate the interior and external harnesses separately. The interior should be fine providing no previous fire from a short or no butchery (radio swaps, old CB radio, etc). All that may need to refresh is a rewrap with the correct tape unless the original can be cleaned up. Try to preserve any tags if they exist.
  The engine harness is exposed to a lot of heat and may get some brittle wires especially on the harness section that runs to the starter motor. If that is too brittle then you can get a repo for that one section. The ignition wire also needs to be checked closely.
I still have my original harnesses on my 67 but I did change a few burnt wires from a donor harness so if you can find a donor you can just replace what needs replacing.
  The trunk harness is usually in good shape providing no external damage. I would try to keep as much of the original harness as possible providing it can be safely done.
How does the fuse box look as far as corrosion?
L78 steve
« Reply #2 on: December 14, 2015, 05:06:09 PM »
You can also send your original harness pieces to AAW and they will repair and re-wrap as needed.
69 Z/28 Dover White. SOLD
Baconcks
« Reply #3 on: December 15, 2015, 04:11:46 AM »
The fuse block is not that bad, the rust ate the upper cowl but the original owner covered the car during the winter. Also the 396 has the smog still on it will it devalue the car if I remove it and save it. I'm going to take your advice and fix the harness if I have to I can splice in wires I can do that.
« Reply #4 on: December 16, 2015, 03:20:10 AM »
I'd give that some more thought as it might be a wise decision to replace and then change out a few connectors from the originals harness to the new one.
A new harness from AAW along with changing some connectors from the orig harness to the AAW harness prior to installation would not de-value the car and depending on the harness condition it might be the prudent thing to do.
Baconcks
« Reply #5 on: December 19, 2015, 01:21:44 AM »
Thanks everyone for the answers
