Author Topic: speedometer cable location  (Read 10675 times)
HustleRussell
« on: November 08, 2015, 09:29:30 PM »
I'm confused about location of speedometer cable thru firewall. Info from c r g says cable should be on left side of column for MC1 trans. My car is #'s matching L48 and MC1. The cable is on the right side of column. Just wondering?
Russ
68 RS
69 SS
Re: speedometer cable location
« Reply #1 on: November 08, 2015, 11:08:01 PM »
That sounds like a super cool ride. You will have to get us some pics. I have never had a chance to examine in person a 3spd. man. SS.I will give my 2cents. I believe, if not specified in CRG, that the default location is where all trans. speedos come out in the pic. that is, to the Left of the strg. column where the plug is circled (on RT. in pic) Only the Muncie 4spd comes out on the RT side (pictured) all the rest Lft.
HustleRussell
« Reply #2 on: November 09, 2015, 12:53:09 AM »
I took some pictures. They wouldn't post bc of size. So I  used phone to take pics of pictures. Today is first time I've joined any forum.
Russ
68 RS
69 SS
HustleRussell
« Reply #3 on: November 09, 2015, 01:00:46 AM »
I'm really confused now. Pictures wont post bc they are over 500 kb.
Russ
68 RS
69 SS
« Reply #4 on: November 09, 2015, 01:47:58 AM »
http://www.camaros.org/forum/index.php?topic=7809.0
HustleRussell
« Reply #5 on: November 09, 2015, 01:49:24 AM »
Firewall after trimming pic to get size down.
Russ
68 RS
69 SS
HustleRussell
« Reply #6 on: November 09, 2015, 01:51:14 AM »
mc1 side cover.
Russ
68 RS
69 SS
ss jim
« Reply #7 on: November 09, 2015, 01:57:22 AM »
My car was originally an L48/MC1 and the speedo cable is in the location shown by Bentley's picture.
HustleRussell
« Reply #8 on: November 09, 2015, 02:15:15 AM »
Transmission cable outlet is on passenger side.
Russ
68 RS
69 SS
« Reply #9 on: November 09, 2015, 02:49:24 AM »
Looked up MC1 in AIM. AIM MC1 A1 under item part #4 6477216 Speedo Cable.  The notation states, "installs same as RPO M20 with RPO L34,L35,L48,L78,& LM1". A new one on me, but according to that, the cable does indeed come out the hole you show. I told you this would be a fascinating study, probably not too many around, my guess.
HustleRussell
« Reply #10 on: November 09, 2015, 03:06:15 AM »
Very interesting. I don't know anything about AIM. Could you elaborate?
Russ
68 RS
69 SS
« Reply #11 on: November 09, 2015, 03:18:07 AM »
A.I.M. is an acronym for Assembly Instruction Manual. It is a bible to restoring a car, like the Camaro, and each manual covers only one specific year.
It is a collection of GM documents listing all the components of an assembly of a particular model car with an exploded view diagram accompanying along with a list of part numbers associated to that assembly. Google it. There is a link on this site and a PDF. Use the search feature here also.
from this site:"The AIM covers Chevrolet-installed parts, including drawings and part numbers (but not Fisher Body installed parts)."
HustleRussell
« Reply #12 on: November 09, 2015, 03:28:53 AM »
Thanks for the info. I still got lots to learn. Do you think CRG should update their 69 info on this this matter?
Russ
68 RS
69 SS
« Reply #13 on: November 09, 2015, 03:43:30 AM »
Welcome aboard! Well, now YOU are CRG ,a group of passionate Camaro guys learning and contributing information about original example F-bodies. To answer your ? If you have accurate, known data that refutes or clarifies a topic, then you contact a moderator on here and they will work to get any  information corrected or clarified.
HustleRussell
« Reply #14 on: November 09, 2015, 03:58:33 AM »
Thanks again for all the help. One more question about my car. Trim tag date 02d. Rear axle code first week in march. Can this be original rear end? It is 3:31 12 bolt.
Russ
68 RS
69 SS
