Author Topic: 67 body number location  (Read 4258 times)
mopar346
« on: September 15, 2015, 12:04:22 PM »
I went and looked at one last night and I didn't find the numbers, any numbers, where I thought they should be so I decided I might be wrong. I believe there is one in the firewall below the fan motor that cant be seen with the fender on and I thought one on the passenger side of the cowl under the vent to the inside of the joint. So what is the truth?
I did look for the page that I have referenced before that had this kind of info on it but couldn't find it.
Thanks in advance, Kevin
FortLangleyBC
Re: 67 body number location
« Reply #1 on: September 15, 2015, 03:09:09 PM »
I have found the hidden VIN on several cars (including mine) looking through the cowl slats on the passenger side - they are towards the front of the car. (see  photo)
I hope this helps :)
1969 Trans Am 400 335 WQ Cameo White
« Reply #2 on: September 15, 2015, 04:07:36 PM »
http://www.camaros.org/numbers.shtml#PartialVIN
You need to pull the heater box to see the lower one.
Petes L48
« Reply #3 on: September 15, 2015, 05:37:19 PM »
I believe there was mention here in the past that the LOS plant stampings could be a bit more random, at least for 67s, meaning you may find only one or the second one upside down or partially stamped at the heater box opening.
mopar346
« Reply #4 on: September 15, 2015, 07:42:58 PM »
Thanks for the info, it's a Norwood car for the record.
Thanks again.
