Author Topic: Idler Arm Boot  (Read 11067 times)
HawkX66
Idler Arm Boot
« on: July 07, 2015, 01:13:24 PM »
Is there a source for a 69 Idler Arm Boot? My idler arm (3917581) is good, but the boot is ripped. Any alternatives if one isn't available? I don't mean like buying a new one... According to David Pozzi's site, there are quite a few differences between what's available a/m and the originals.
Thanks.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Boston14
Re: Idler Arm Boot
« Reply #1 on: July 11, 2015, 11:45:19 PM »
If I remember correctly from when I rebuilt mine, both the idler and pitman arms use the same boot (right down to the part number on them).  These are available at Heartbeat City among other vendors.
boston14
1969 SS/RS 350 Convertible
Re: Idler Arm Boot
« Reply #2 on: July 12, 2015, 12:40:52 AM »
HawkX66
Re: Idler Arm Boot
« Reply #3 on: July 12, 2015, 01:46:11 AM »
Thanks guys I'll check it out. I appreciate the info.
Dave
Semper Fi!
HawkX66
Re: Idler Arm Boot
« Reply #4 on: March 01, 2017, 06:24:27 PM »
Just in case anyone comes across this thread, the boot from HBC was very different. I might try de-greasing mine real well and use some rubber cement.
Dave
Semper Fi!
Boston14
Re: Idler Arm Boot
« Reply #5 on: March 02, 2017, 11:50:30 AM »
Sorry, I was referring to the seal at the center link .................. I didn't notice the picture you posted when I replied.
boston14
HawkX66
Re: Idler Arm Boot
« Reply #6 on: March 02, 2017, 12:50:50 PM »
No worries. I appreciate the try.
Dave
Semper Fi!
jeff68
Re: Idler Arm Boot
« Reply #7 on: March 03, 2017, 05:25:46 PM »
I would suggest using an adhesive such as Loctite 380 (aka "Black Max").  It should work very well in an application like this.  We specify this at work for bonding split o-rings.
HawkX66
Re: Idler Arm Boot
« Reply #8 on: March 03, 2017, 05:59:00 PM »
Thanks for the suggestion Jeff. I'll give it a shot.
Dave
Semper Fi!
L78 steve
Re: Idler Arm Boot
« Reply #9 on: March 03, 2017, 08:52:08 PM »
Crazy glue. We use it to make O-rings.
69 Z/28 Dover White. SOLD
HawkX66
Re: Idler Arm Boot
« Reply #10 on: March 03, 2017, 09:21:02 PM »
Thanks Steve. I'll do a couple of tests and see what works the best. It seems to be more of a dust boot and doesn't hold any real pressure, so hopefully one of these will work once the weather warms up a bit. I should have tried this a long time ago.
Dave
Semper Fi!
jeff68
Re: Idler Arm Boot
« Reply #11 on: March 05, 2017, 03:54:36 PM »
Crazy Glue and Loctite 380 are both types of instant CA adhesives, usually referred to as 'super glue'.  Regular chain store super glue is usually brittle, and while it bonds to rubber very well, it is not flexible.  Loctite 380 is a rubber-toughened with some flexibility, so it's usually the go-to glue to use for bonding o-rings and other rubber that is required to flex a little.
HawkX66
Re: Idler Arm Boot
« Reply #12 on: March 05, 2017, 05:30:37 PM »
[/quote
Thanks Jeff. I was thinking that might be the case. I knew super glue dried brittle.
Dave
Semper Fi!
