Author Topic: Valve covers  (Read 4925 times)
Barry J
Valve covers
« on: June 16, 2015, 06:21:06 PM »
Right now I have old chrome high profile vavle covers on that I've had for about 20 years. I would like to change them. Is there any reason why I can't switch to a low profile type?? Also, thinking on going with the black ones, will that look good with my orange engine and aluminum intake??
Thanks Barry
Re: Valve covers
« Reply #1 on: June 16, 2015, 07:11:12 PM »
Based on the limited information Q1) No, Q2) Yes...guess that is what you want to hear?  When it comes to valve covers or women's apparel, low cut is always preferable...I'll ad, black is only for formal occasions though, I assume?
But, now a question for you, Barry. I am thinking about
changing the lighter in my ashtray, should I go with the "Save the Ta-tas" breast awareness theme on the top portion of the lighter or the "Paisley, lost in the Hippie era" look? Hmmm? Decisions!?
Oh, and welcome to the site.
BSMIT59
Re: Valve covers
« Reply #2 on: June 16, 2015, 07:23:13 PM »
Bentley you should be doing standup comedy somewhere..................
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
vtfb68
Re: Valve covers
« Reply #3 on: June 16, 2015, 08:08:04 PM »
Barry,
 "tall" valve covers are used to clear rocker arm travel on engines with a hi-lift camshaft. If your engine does not have these type of rockers you should be fine with "low profile" valve covers.
  Google engines pictures.
   Good luck,
    Victor
68 08E LA RS Y2 749 L30 M35
69 Zee
Re: Valve covers
« Reply #4 on: June 23, 2015, 04:59:37 AM »
Here you go Barry ... just as described, almost (these are high but you get the picture) :o   But even better is if it's gonna be in, oh lets say  ???  A Hugger Orange Camaro   ;D
Darrell
Re: Valve covers
« Reply #5 on: June 24, 2015, 09:16:55 PM »
VTBF68 is correct :) I prefer the look of tall valve covers ,however leads to some minor alternator clearance issues on 67-68's---smaller diameter belt solves the problem, usually. Set of Morosos I has needed very minor mods.
