Author Topic: HEADS/BLOCK/MANIFOLD HELP  (Read 6298 times)
jasonw
« on: October 12, 2006, 12:58:05 AM »
I bought this car 21 years ago and it has not be registered since or driven.I'm finally going to restore it back to as original as possible.I thank all of yall,yes that means I from Houston,Texas .thank all for your help.I bought the car as an rs and thinking most of it was original. Would this be considered an matching engine.
CODES ON ENGINE
BLOCK T0406MM  FRONT PAD
BLOCK 3903352    ALSO D47   BACK OF BLOCK
HEADS 3917291   ALSO C227  BOTH ARE THE SAME
MANIFOLD  3905393  ALSO C147
« Last Edit: October 12, 2006, 11:35:24 PM by jasonw »
Re: HEADS/BLOCK/MANIFOLD HELP
« Reply #1 on: October 13, 2006, 02:28:06 PM »
What's the data for the car to match it against? VIN, cowl tag, model year, trans, axle, VIN derivative stamped on the engine, etc. ?
« Reply #2 on: October 14, 2006, 02:26:55 PM »
Here's the data, still waiting for the VIN:
Thanks for responding,Heads 3917291   C227,Manifold 3905393,
Trans T7E05D,Axle PA0426G1,Engine Pad T0406MM NoVin
Stamped There,Back of Block 3903352 also D47     352
        948
05A                                               G
67-12437                 NOR 117308
709Z                                   S-2
E 2EMG  3SL
