Author Topic: Ignition Coils  (Read 17342 times)
my69Z28camaro
Ignition Coils
« on: January 24, 2014, 11:04:03 PM »
Does anyone know where in the CRG material I can find a list of the GM P/N for 1969 ignition coils or do you have a complete list of 1969 ignition coil for each Camaro engine?  I am trying to verify if my '270 is correct for my 1969 Z.
69 Z28 RS X33 50 A 713 Endura Console Rosewood
Re: Ignition Coils
« Reply #1 on: January 24, 2014, 11:18:29 PM »
Ignition coils are not yet listed in the CRG research data.  You can do a "270 coil" search on the home page and lots of related CRG threads will magically appear!   :)
Re: Ignition Coils
« Reply #2 on: January 24, 2014, 11:26:58 PM »
And also Team Camaro! The search key can be most productive! And welcome aboard "my69Z28camaro"
my69Z28camaro
Re: Ignition Coils
« Reply #3 on: January 25, 2014, 09:51:39 PM »
I did some searching in the "Team Camaro" web site on this subject and the results found in a blog string showed:  1115298 - Z28 with flat hood and non-TI;  1115270 - LM1 & Z28 with ZL2 hood and non-TI;  1115293 - All other V-8's SB & BB with flat hood and non-TI
In another section of the CRG, it lists for TI coils:  1115210 - ZL1 and 1115207 - Z28
Do the members agree on these finds?
Re: Ignition Coils
« Reply #4 on: January 25, 2014, 10:04:05 PM »
270 is the correct one for the ZL2 hood, and 298 is correct for a flat hood car.
Re: Ignition Coils
« Reply #5 on: January 26, 2014, 01:00:41 AM »
Here's the Delco Remy catalog pages from Oct. '68. Note the distributor listings are correct, as are the point sets and other parts, but is only lists 2 coils to cover the entire engine offering. Interesting -
Hope these are readable - I had to convert from pdf to jpg and then downsize.
Regards -
Re: Ignition Coils
« Reply #6 on: January 26, 2014, 06:13:41 AM »
From broadcast sheets, in 69, there were three coils (probably 4 including L6 cars):
- Z28
- SB with ZL2 cowl hood
- All others (LF7, L14, L35 w/ ZL2, L48, L65, L78, ZL1)
Re: Ignition Coils
« Reply #7 on: January 26, 2014, 04:25:03 PM »
Remember that those Delco wholesale/retail catalogs refer only to the part number of the coil itself; the part number shown in the Assembly Manual is for the coil AND ITS MOUNTING BRACKET, a "coil assembly".
69Z28
  • 69 X33D80 Z28
Re: Ignition Coils
« Reply #8 on: January 26, 2014, 06:12:00 PM »
- Z28
Hey Kurt doesn't the LM1 fit into the 'others' list? My survivor 69 Impala has a #298 on the coil.
GaryC
Re: Ignition Coils
« Reply #9 on: January 27, 2014, 03:32:30 AM »
Should have added an etc.... Several other engines are not listed too.
69Z28
  • 69 X33D80 Z28
Re: Ignition Coils
« Reply #10 on: January 28, 2014, 06:36:16 PM »
Kurt...Something I saw on ebay prompted me to ask. I always thought the 69Z28 only had the 270 or the 293. HBC has an auction going for a #298...check out the link. Is HBC correct? I always had the impression those guys were knowledgeable. Heck I have 3 or 4 #298's just sitting around. At $500.00 apiece I can buy my correct dated alternator then.
http://www.ebay.com/sch/6000/i.html?_nkw=298+z28+coil&_dmpt=Vintage_Car_Truck_Parts_Accessories&_rdc=2
GaryC
Re: Ignition Coils
« Reply #11 on: June 05, 2017, 04:21:22 PM »
So if the coils are the same out side dimensions, internally were that that much different from one application to the next? I understand the different coil brackets for the ZL-2 hood, but why a different coil number? 298 vs. 270?
Also I see the 293 coil as well for 69 Camaros. why would there be a need to have so many different ones?
