Author Topic: Hood Part numbers  (Read 8601 times)
red69
Hood Part numbers
« on: December 30, 2013, 01:18:52 AM »
What is the difference between hood part numbers 3938617 and 3938619? Thanks
Mark
Re: Hood Part numbers
« Reply #1 on: December 30, 2013, 01:31:04 AM »
617 is your standard flat hood 67 to 69 hood, 619 is the SS hood with the power bulge and openings for the hood ornaments (the big block SS velocity stacks, or small block louvered trim pieces).   3949708 is the 69 Ducted (cowl induction) hood.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #2 on: December 31, 2013, 05:52:36 AM »
So this is a big block hood?
« Reply #3 on: December 31, 2013, 08:48:00 AM »
Not necessarily, depending on the build date it could be a small block...  http://www.camaros.org/forum/index.php?topic=6470.0
« Reply #4 on: December 31, 2013, 09:44:22 PM »
A true '67 SS hood had a different part number than the later '68-'69 version. The 'stacks' required punched holes for the drains.
« Reply #5 on: December 31, 2013, 10:57:39 PM »
And original 67 hoods didn't have the drain holes and rubber drain spouts added like in 68-69. That's why so many rotted out from the inside-out.
plumL78
« Reply #6 on: January 01, 2014, 05:33:53 PM »
Here is a real nos 67 ss hood 3898129
« Reply #7 on: January 01, 2014, 06:33:21 PM »
'Plum',
    And no drain holes and rubber spouts, correct?
plumL78
« Reply #8 on: January 01, 2014, 07:16:58 PM »
correct no drain holes
