Author Topic: restoring 69 hood hinges  (Read 16355 times)
Charley
Re: restoring 69 hood hinges
« Reply #15 on: August 30, 2013, 12:06:39 AM »
It would be great if you tried it and posted pics.
DT
« Reply #16 on: August 31, 2013, 08:57:34 PM »
I have to find a cheap Large SS pot to put hinges in, LOL
Donny
Rich69s
  • Two years in the making
« Reply #17 on: March 25, 2014, 12:23:10 PM »
I used a nesco type roaster for my hood hinges with thee gallons of water and 12 oz. of the dark gray phosphate . It worked great on both set of hinges. Make sure you degrease the pivot point really well before you blast them, then right into the solution.  Let it cook about 8 minuets after it stops bubbling then right to WD 40 rinse and dry three times. The next day I treated them with Barricade
  Use a thermometer, It takes awhile for the cooker to reach 190 degrees.
1969 L 48 SS Frost Green taken apart in 1979 resurrection forthcoming
1969  Yenko  Purchased 1981 with my student loan check
KevinW
« Reply #18 on: March 25, 2014, 05:42:51 PM »
I used stainless steel paint as a primer, then a very dusty thin coat of cast blast to tone it down, then a very fine misting of satin black to further darken it.  May not be correct, but it looks good and should last. other than the primer coat, the others are sprayed far away so the paint gets a rough texture and is not smooth.  I did this to the hood latch too. Sorry, I do not have a pic loaded online showing this.
