Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
what engine motor mount did you use on z28
« previous
next »
Print
Pages: [
1
Author
Topic: what engine motor mount did you use on z28 (Read 4101 times)
BillOhio
Hero Member
on:
April 01, 2013, 02:58:08 AM »
Getting parts ready to install engine and noticed the mounts on engine were the original non locking ones. One had a crack in rubber so I figured to get a new set. Is it a good idea to switch to the locking ones? I think the wider one was the cracked one.
Tweet
Logged
1968 RS 327 4 speed
lynnbilodeau
Member
Re: what engine motor mount did you use on z28
Reply #1 on:
April 09, 2013, 04:02:36 AM »
Well, GM switched to the locking ones eventually. Unless you are planning to have the car judged in a class that will ding you, I would just use the Anchor replacment interlocking mounts. Just put a pair on my 69 Z and they fit perfectly.
Logged
Hero Member
owner since 4-Apr-1976
Reply #2 on:
April 09, 2013, 04:18:45 AM »
Optionally, use your remaining orignal good one on the RH side (passenger side of the engine) and buy an interlocking one for the LHS... GM may have even swapped out some LHS units for interlocking ones during first year maintenance activity??
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
Print
Pages: [
1
« previous
next »
Restoration
