Author Topic: 67 350 metal vacum line correct  (Read 4264 times)
pracing
« on: December 19, 2012, 07:32:07 AM »
Going back to the organal carb on my 67 RS/SS 350/295 Hp & looking for the correct vacum line routing from dist to carb. It had a holley carb & it not sure if the metal line is correct
Re: 67 350 metal vacum line correct
« Reply #1 on: December 19, 2012, 02:54:39 PM »
The 67 L48 engine (350/295) used a Rochester Q-Jet, so you need to get THIS ONE.
« Reply #2 on: December 21, 2012, 12:32:19 AM »
Hey pracing -
I've got one of these if you need an original - be glad to send it to you if you'll pay the freight. I'll try to dig it out of the frozen garage tonight and get a pic if you want -
« Reply #3 on: December 21, 2012, 12:54:26 AM »
Maybe its correct for the q-jet but for our Holley set up the kits have the wrong small piece to the carb. Our orig. vs. a piece of the stripped vac. hose.
Our original
Original to left vs. kits piece.
« Reply #4 on: December 21, 2012, 04:09:14 PM »
I've been told that the DOC REBUILD vacuum hoses are "correct". I haven't checked it out myself, but the same hose was used throughout GM for a number of years, not just Corvette and Camaro.
By the way, there are a couple of good pictures of the Q-Jet tube and hoses in THIS thread. This engine is a 68 L30 (327/275) but the setup is the same as the 67 L48 engine (350/295).
