Correct Belts (engine compartment)
Started by IZRSSS, June 30, 2011, 07:23:22 AM
IZRSSS
I have two different belt designs. Can someone tell me which one is correct, and can you tell me which supplier you use?
Thanx
Marty, it's difficult to tell by the pictures, but both appear to be aftermarket and not original GM belts.
And all GM belts were smooth. Ribbed is an aftermarket thing.
69znut
Ribbed is correct. Ricks Camaro's or any NAPA auto parts.
Ribbed belts generate less friction and heat on the smaller diameter pulleys because of the notched area allowing flex compression.
Smooth belts compress on the inner radius of small pulleys and the narrow side actually bunches up to generate heat and eventual fatigue.
They are better suited for industrial applications but were used on much older cars too.
rat pack
69znut, I am not sure where you got your information but the "ribbed" or "cogged" belts were never used on any first gen Camaro. I don't think I have ever seen any Camaro from the factory with that style of belt unless it was serpentine...............RatPack..................
The "cogged" belts (like Dayco "Top-Cog" and Goodyear "Gatorback") are functionally superior to the normal smooth V-belts, but cogged belts were never used in production on 1st-Gen Camaros. I've used the Dayco cogged belts on solid-lifter small-block Corvettes for many years, and have never lost one or had one "flop over"; however, they don't fly in judging - that's when the Quanta reproduction belts go on.
IZRSSS
Great information gentlemen...much appreciated!
