1969 Flat Hood Original??
Started by Iowa Jon, September 01, 2026, 06:21:39 PM
Iowa Jon
I always assumed this hood was original. However I recently removed the paint from the drivers side corner and can't seem to find a week stamp. Is there any other location that this stamp may have been placed? Thanks
KevinW
x66 714
If it was light enough, you may have already sanded it off. One of my original hoods has the stamp on that lower edge that you still have paint on. Almost looks like a "1" showing through when I enlarged the picture.....Joe
Iowa Jon
Quote from: x66 714 on September 02, 2026, 07:19:25 AMIf it was light enough, you may have already sanded it off. One of my original hoods has the stamp on that lower edge that you still have paint on. Almost looks like a "1" showing through when I enlarged the picture.....Joe
Thanks Joe, I will post some more pictures. Maybe there are some details on the hood that would help date it. My car is an 05a 1969
Iowa Jon
Here are some more pictures when I pulled the hood out of storage. I have an aftermarket cowl hood. I want to go back to the flat hood.
x66 714
It's for sure a 1969 hood. The holes are different on a 69 hood. I just had to help find one for a zero option 1969 Z/28. There are 2 different for 1969. Your's appears to be the 1st design. The second design has triangles near where the hood mat would mount at the front....Joe
Like that you're going back to a flat hood
Iowa Jon
Thanks Joe, I did not know that about the triangles. I did read the information that is in CRG about the hoods. I was not sure if this design would have been first or second and what the cut off date may have been. Now that you have helped me identify that it is 1st design, I wonder if my 05a z28 is too late for the 1st design? I'm never quite sure if may build is considered early or late? Seems like a lot of changes occurred in the April, May builds. My car is a Norwood built Z28 x77. No tach, console but no gauges, factory installed spoiler, air dam. That's it. Very basic z. Yes, I like the flat hood. Thanks for the help.
FRANKTHECRANK
Not sure on a 69. Mine is 05C and I believe that considered late for a 68. But, seeing that the 69 model ran for so long before the 70 1/2 Camaro was introduced, I don't know if May was considered late in 69.
Smartin72!
General question, but if you go back to a flat hood for a 69', you need to change the air cleaner as well, correct?
Iowa Jon
Hi, Yes I will change the air cleaner.
