Main Menu
67 l30 m20 convertible rear springs
Started by philip, January 28, 2026, 12:36:40 PM
Previous topic - Next topic
CantRepeat
Quote from: bcmiller on February 05, 2026, 09:56:53 AM
Quote from: CantRepeat on February 05, 2026, 06:39:57 AMKurt,
What is the model 37 in reference to?
I am not Kurt, but can answer.
37 - coupe
67 - convertible
It is from the VIN.
Thanks Byron! It's obvious I'm working with less gray matter every day!
-Tim
philip
1 of 359 L30M20 67 convertible ( sold new in 01/67 in 🇫🇷)
RPO: A02-A31-A67-B37-B93-C06-D55-F41-G80-J50-J52-K02-L30 -M20-N33-N40-N61-U17-U18-U25-26-27-28-29-V31-V32 Z21-Z22-Z87
philip
philip
philip
Was there a rubber spring isolator pad in place between the leaf spring and the spring perch when you took it apart?
Bryon / 1968 Camaro SS 396 coupe - now 468   /  1967 Camaro RS/SS 396 coupe L35/M40 - project / 1970 Nova updated L88 M40
philip
Quote from: bcmiller on February 06, 2026, 01:28:28 PMWas there a rubber spring isolator pad in place between the leaf spring and the spring perch when you took it apart?
Only on top , no below....
philip
philip
Do you know if the ref of the spring is stamped on the leaf (3909941 or 3920220 for my car ) ?
 If yes , where ?
I know there's a paper tag with 2 letters  but in about 60 years , gone..
There are not stamped #'s on the springs.
philip
Thanks kurtS.....i will send you by email a PowerPoint a friend make several years ago to explain the differences between US and french model.
So what to do ? Réinstall the added leaf or remove it ?
MO
Technically, if they can't be validated, they should be removed. However, it's your car, and if you want to keep them on then do so. It really depends on what your goal is.
I don't think they are original but I can't say for sure.
If proof can be found that they are original, I would be interested in knowing the details as to when, why and how the change was made.
Best wishes.
I'd tend to install them - at this point the original springs are probably a bit tired.
philip
Ok 1 side done, i have réinstalled the second spring
I have installed also a bolt on subframe connector.
Thanks for your help.
I will continu to investigate about these springs.....
