1969 Cowl Hood Spring
Started by Iowa Jon, June 13, 2024, 02:05:14 PM
Iowa Jon
Hello,  I read through the CRG Under hood Components for the correct Cowl Hood Spring.  The chart says 8 3/4  , 26 coils.  Part number.  GM - 3877203.  Spring fits standard and cowl hoods.  I have ordered a couple sets.  The first set was OER.  The spring measures 7 1/2. and 26 coils.  The next set i ordered measured 8  3/8 and 23 coils.  Non of the measurements were available until i received the springs.  Of course they are all incorrect.  The next company told me that only the Standard hood received the 8 3/4 spring.  They even list it on there description.  (  1967 - 1969 Camaro Hood Hinge Spring, Standard, Each, 409025
High quality correct spring rate for use with the flat steel hoods. Sold individually, 2 required per vehicle. This fits all 67, 68 and 69 Camaros, but will various GM models with standard hoods. (Not for SS or cowl induction hood) Replaces GM part number 3877203.)
So is the correct hood spring "GM - 3877203" for Standard and Cowl?  Better yet is 26 coils and 8 - 3/4 correct.
I figured these springs would be easy to find.
GMPD listed only two springs for a steel hood.
#3848272 for the SS hood.
#3877203 for standard and ducted hood.
Back in the day, I swapped out two standard hoods for a ducted hood on my Z/28s. Never touched the hood springs.
Iowa Jon
ok,  Thanks,  I figured the chart at CRG was correct.  Its sometimes hard to explain that to these companies.
The company I bought the OER springs from even opened up another set and they were 7 1/2.  They must have all been labeled wrong at OER.
Found a pair of NOS but I can't seem to part with $650
Iowa Jon
Just received a reply back from Heartbeat City.  They said 7 1/2 is correct for Cowl hood and Standard.  Told me they would refund my money.
Ugh
Iowa Jon
Just spoke with Classic Industries.  They measured there OER springs.  7  1/2.
Iowa Jon
Filed a complaint with OER.  Just got a message from OER and they sampled there springs and the wrong part numbers were on the packaging.
Sauron327
Cowl induction or flat hood springs are easily obtained. I had a surplus and sold some to my hinge restorer. I still have some I think. SS springs can be purchased new. In fact, he supplies SS springs when he rebuilds hinges but I did not need them so I sent them back.
Dave69x33
I am also searching for a replacement set of correct 3877203 hood springs for my '69 Z28 with cowl hood.  My original 203 springs are weak and will not hold up the hood.  In March 2023 I purchased a "correct spec" pair of hood springs from HBC, item #BDY-1516 which were OER brand springs.  They worked fair but still allowed the hood to droop down about 4-5" from full up against the hood stop build into the hood hinges.
Recently, with the hood up and the car idling, the hood slammed shut.  NOT a good or safe thing! If I pull the hood down about a 1/3 of the way, the hood will fall and slam shut.  This could be a liability at a car show with your hood open and someone's head or hands are in the way!  Until I can find replacement spec springs with the proper tension, I wrap a strip of Velcro around the hood hinge to make sure the hood stays open.  This looks a bit better than an cut off broom handle used as a hood prop...lol.
I may try sand blasting my hood springs. This will input some compressive stress in the surface material of the spring which may help improve the tension in the spring. As long as you do not get the spring hot and stress relieve (anneal) and "soften" the material, sand blasting the springs should be okay to test.  Its a cheap method to test but I do not have much confidence this will work.
If anyone find a set of springs that work well, please share your source, brand, and item number. There may be the same spec (size, no of coils, etc.) as the 3877203 springs under a different part number used on another GM model car but I have not yet found one.
Dave
Dave69x33
BTW...I did inspect my hood hinges for loose rivet pin holes and they are tight.  The slots that retain the ends of the spring in the hinge appear normal without any elongation.
Sauron327
Call Wiilie. He's the person I've had do dozens of hinges for all makes and models. He may have the pair of springs I recently sold him, or others he has in stock.I may have another pair somewhere else but it will be a while before I get them and/or remember. https://www.hoodhingerepair.com/about/
Dave69x33
Sauron327,  Thanks for the tip!
Iowa Jon
Hi Dave,  I finally bought some reproduction hinges from Jegs for $11.67 each.  They have the correct number of turns but they are only
8 - 1/2 inches long.  CRG lists the correct length as 8-3/4.  They fit really well and they are a little strong when I raise the hood. There was a listing on Ebay for $80 for a set of used originals.  I reached out to the seller and he communicated quickly. He measured them for me and said they were 8-3/4 .  I decided to pass
https://www.ebay.com/itm/234905974465
Dave69x33
Thanks Iowa Jon.  I'll check them out!
Iowa Jon
I bought the Springs from Jegs.  I accidentally said Hinges.  You probably knew what a meant.
Dave69x33
Yeah, thought you meant the springs. I purchased the original used hood springs listed on eBay. Thanks again for the tip!
Iowa Jon
Dave69x33
Just tested the clean original 3877203 hood springs I purchased on eBay. Unfortunately the spring tension is very weak and they do not hold the hood up. My hood is the original cowl hood so the 203 spring is the correct spring.  Just like my original hood springs, they allow the hood to fall and slam shut.
I reinstalled the OER reproduction springs for now as they will hood the hood open but as soon as you begin to pull the hood down, I must hang onto the hood or it will slam shut. My only other option is find a better quality repro set of springs.  I use the springs from Jegs that Iowa Jon used.
I guess we cannot trust a used set of springs.
Dave69x33
Iowa Jon,  just discovered Jegs offers OER item #3907627 hood springs listed for 1967-69 cowl hood. I believe the OER springs I purchased from Heartbeat City Camaro are the same springs, but my OER spring tension is not as strong as what you described.
Iowa Jon
Hi Dave,  let me walk through this issue.  I did order springs from Heartbeat City.  Item #3907627.  See pictures below of wrong mislabled spring from OER/ Heartbeat City.  These OER springs were the correct number of turns but only 7-1/4 long.  I told Heartbeat and they said they would look into the issue. A week went by and no communication.  So I called them and they said that 7 -1/4 was the correct length for 1969 Camaro standard and cowl hood springs.  I disagreed and told them I had spoke to OER myself and gave them the gentleman's name. I explained that the man I spoke with at OER  confirmed that the springs where labeled wrong from OER. These same mislabeled springs were also sent to Classic industries. They confirmed with Classic Industries the batch of springs they received were also mislabeled.  So the item number #3907627 are not for a 69 Camaro with standard or cowl hood.  Heartbeat was not interested and they refunded my money. So OER said "call JEGS this is the correct part number (GM 3877203) JEGS # 78592.  Jegs went and measured the springs for me.
Heartbeat does not list the 3877203 spring.  Jegs is selling the correct 203 spring and Heartbeat is selling 627  as the correct spring.  I can tell you the 203 spring from Jegs is not falling down.  Look up the JEGS number #78592.  Keep me posted.
correct spring although as i stated in another post it is off a little in length.
https://www.jegs.com/webapp/wcs/stores/servlet/SearchResultsPageCmd?q=3877203&storeId=10001&catalogId=10002&langId=-1
169INDY
Wow, Thank you for your efforts and sharing.
R.E.M. is a Manufacture of restoration parts and Is ALSO not interested in Feedback,  I understand your frustration.
Keep at em Boys!
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Iowa Jon
7 1/2 not 7 1/4 wrong regardless.
Dave69x33
Thanks!  I check out the Jegs springs.
Quote from: Dave69x33 on July 09, 2024, 06:18:01 PM
My car still has the factory hood springs with the original cowl hood. No issues.
I think your hinges may be worn out....
Dave69x33
Kurt,  I checked the rivet pivot points for wear a did not find any loose joints.  Checked the spring attachment slots and they has some wear but still look good.
Sauron327
I'm going to assume the hinges were checked for any play with the springs removed. At one point I had a dozen in stock and all had some play to varying degrees at some or all pivot points. Now down to a couple pair as backup.
Dave69x33
Sauron327,
Good point. I will remove the springs and recheck the rivet points for sloppy joints.  Thx!
Dave69x33
All,
I received the Jegs #78592 hood springs today. They work great and keep the hood up even when I close the hood nearly halfway. The hood stays put and does not slam shut. Thanks for the tip about Jegs hood springs!
I did not get a picture of the Jegs springs side-by-side next my original springs but they look nearly identical.
The only issue for me is they are painted a nice satin black. To be technically correct the springs should be gray phosphate plated. I have it on my winter project list to have a local plating shop strip the paint and plate them. Just glad I finally solved the "hood will not stay up" issue.
BTW...learned a great way to remove/install hood springs. Cut a fan belt in half and loop it thru the hook end of the spring. Protect your fender with a fender cover. Brace your body against the fender and pull the spring hook off the hood hinge. It's easy and quick!
Dave69x33
When I installed the new Jegs hood springs, they were considerably stronger (higher tension) than my originals and the repro OER springs I purchased last year from Heartbeat City Camaro.
Dave69x33
Update...My hood droops closed on its own....again!
The new Jegs hood springs worked at first to keep my hood open but now the hood closes on its own just as it did with my original hood springs.  For now, I re-installed the SS hood spring to keep the hood open. Even with the SS hood springs, the hood tend to droop down about 4 - 5 inches.
I need to focus on the hinges because they must have too much wear in the rivet pivot joints.  I plan to prop open the hood, remove the spring, and unbolt the hinge from the hood (one hinge at a time) to get a closer look for loose rivet joints.
I assume my hinges are warn out and will consult with Willie Wilson at Hood Hinge Repair.  Based on reviews they do good work, but I prefer they not paint the hinges so that I can have them re-plated in gray phosphate as original.
I will keep you posted!
Sauron327
I speak with Willie semi-often about jobs, cores, rebuilds and work in general. Lost track of how many he's done for me. As of this week he had shoulder surgery and is backed up. Good luck finding someone to do it ASAP.  Those doing it do not need the work so you'll have to be patient. Willie offers rebuilt functional hood hinges and an option with correct looking rivets. He just sent me rebuilt 67 door hinges for my car because someone backed out. Willie's 67 rebuilt door hinge detent roller rebuilds use superior custom machined bronze bushed parts. The 67 kits from repro houses use hardware store generic small diameter allen head, threaded and shouldered roller detent bolts. I've seen them snap. Why wouldn't they under that pressure? Willie presses the correct roller rivets in.
