Rear End Housing Spring Perch Welding
Started by jim68, February 19, 2020, 09:46:05 PM
jim68
Looking to have a set of spring perches welded onto my 12 bolt. Is there anyone out there who has had this done and is happy with the quality of work? I live in the Massachusetts.
Thanks.
jcihos
I had my father in-law weld the spring perches on my rear end and they came out perfect.
crossboss
Quote from: jim68 on February 19, 2020, 09:46:05 PM
Thanks.
Try your local trailer hitch installer or a reputable muffler/exhaust shop. Any good welder with a MIG can do this simple job.
1968 Olds 442 W-30
169INDY
(Specialty) Rear End shops also should be dialed in on this, Like a Randy's Ring & Pinion service "IF" they are local to you?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
JKZ27
Welding it is relatively simple for a pro but making it look factory is a different story. And, there are a lot of angles involved in their placement so do some research.
John
68 RS Ash/Ivy Gold 327EFI M20
jim68
As far as the angles I've done too much research ha ha
crossboss
Quote from: jim68 on February 21, 2020, 10:48:56 AM
1.5-2 degrees is a 'general' measurement for most pinion angles on domestic rear wheel drive cars. That 'should' put you in the ballpark.
1968 Olds 442 W-30
rszmjt
Pay a professional to weld it, many axle tubes have been ruined by excessive heat by inexperienced people. Also the repo perches need lots of grinding to make them work correctly. If you can borrow a known good housing you can make a jig on the bench and tac the perches on at the correct location and angle then have someone final weld them.
hihorse
Please post a pic of a jig, would like to copy it
jim68
I'd be interested in what the jig looks like also.
Tinkerr
Just use the google machine there are several examples. It's basically a solid shaft that goes through the axle tubes and the housing with bushings for the axle bearings and carrier bearing to make sure everything is straight and true when you start and the same when you finish welding on it.
