1968 302 MO Engine 18L336199 - MacNeish Certified
Started by SandSStClaire, August 19, 2026, 12:17:50 PM
Previous topic - Next topic
SandSStClaire
I found a 1968 302 MO engine with partial VIN 18L336192. Jerry MacNeish has inspected and certified the engine as authentic. I am trying to locate the original Camaro, which I believe may be VIN 124378L336199, Assembly stamp V0321MO, Block casting 3914678.
What is the block casting date?
Is it just a bare block?
Bryon / 1968 Camaro SS 396 coupe - now 468   /  1967 Camaro RS/SS 396 coupe L35/M40 - project / 1970 Nova updated L88 M40
x66 714
SandSStClaire
Quote from: bcmiller on August 19, 2026, 12:55:52 PMWhat is the block casting date?
The block casting date is March 13, 1968
The partial vin number was a misprint. It should be 18L336199.
No it's not just the block. I have the crank pistons and rods, and also a set of camel hump heads with the correct casting number but the date code is off a couple months.
SandSStClaire
Quote from: x66 714 on August 19, 2026, 02:18:02 PMIt's 336199, not 336192....Joe
You are correct Joe, we just caught that.  Thank you.
