Main Menu
Re-attaching Camaro Fender emblem
Started by Smartin72!, October 07, 2026, 10:03:00 AM
Previous topic - Next topic
Smartin72!
Hey all, so my passenger side "Camaro" fender emblem came loose and eventually came off (I think the fasteners behind the fender came off).  I would like to re-attach it with barrel nuts to avoid removing the fender.  I bought the correct size barrel nut for a 1/8" emblem pin, but they do not fit in the hole on the fender. Doing some more reading, due to the paint build up by the hole, the size of the hole is smaller.  One of the methods suggested on line was to take a 5/32 bit and by hand and gently ream out the hole enough so the barrel nut will fit.  I taped off the area and carefully gave that a try, but the barrel nuts still will not easily go in and I don't want to force them for fear of chipping the paint.  Any other suggestions on how to attack this?
boomer632
06A X66 711 57 57 M22 BU
I Thought you "Can" loosen the two bottom lower bolts and maybe a pair of wheel well (Inner) bolts and pull fender away enough to get your hand & wrist thru to install proper hardware in a pinch>?
Smartin72!
Hi boomer632,
Yes, all the emblem pins are present.
169INDY - if that's an option and I can get my hand behind there to put the fender fasteners back on, I would rather do that then drill out the fender holes....
GMAD_Van Nuys
Smartin72!
I just did this on a job with barrel nuts and not for the first time. I use a file on any holes needed to accept the barrel nuts, and simply pushed the emblem on. Epoxy paint was applied to the holes prior to nut insertion. Test the barrel nuts on the emblem studs first to see how much they open. Sometimes the stud diamenter is large and needs to be filed. Easy job. The emblems do not sit proud of the fender using the barrel nuts. On a non-pampered car I did 25 years ago using barrel nuts there was no rust at the holes. Obviously if the car is a trailer queen this method will fail inspection if they notice. Previously on this car someone used thin adhesive tape cut to the letter shape.
