Main Menu
restoring hood hinges
Started by BillOhio, September 30, 2026, 10:08:26 PM
Previous topic - Next topic
BillOhio
Hi guys.  I have a set of hood hinges I want to phophate.  They were painted and I found a foil pan at dollar general that I soaked them in.  Was not the best fit but worked.  I was wondering if anyone found anything big to heat them up in for the phosphate?  I read where someone used an old stainless sink and would like to get them done quicker than looking for an old sink.
1969 Z28s, Burgundy and Rally Green
1968 RS 327 4 speed
1970 Z28 M22 4:10
1969 RS legend certified
BillOhio
I do see lowes has a $62 single bowl stainless sink.  Cheaper than pots! It may have some insulation under it but may be worth a look
1968 RS 327 4 speed
1970 Z28 M22 4:10
Check FB Marketplace or one of the Habitat for Humanity ReStore locations.
Bryon / 1968 Camaro SS 396 coupe - now 468   /  1967 Camaro RS/SS 396 coupe L35/M40 - project / 1970 Nova updated L88 M40
Petes L48
I used an old stainless food service tray/pan I had laying around, the type you see in a cafeteria food line. But buying one new would be costly. Porcelain coated pots or pans will also work, if you can find one large enough.
I used a Old Omegasonic SS Sink, now that I think about it would a Large diameter Plastic Tube with on end capped and submerge them collapsed. Just a hair brain thought not sure
BillOhio
I secured a sink and a single basin will hold a hood hinge.  I bought a lpg burner off amazon for under $40 and will see how this works.  My grill is wood pellets so I may see if dad notices his grill tank is missing!!
1968 RS 327 4 speed
1970 Z28 M22 4:10
I had mine phosphated due to the large pan need BUT as aforementioned a friend purchased a used large restaurant pan.  Another friend purchased a large pan at Best Buy but it was around $300. Dang..... He has a business so it made sense to him but the sink sure seems like a way to go dollar wise.....
