Main Menu
Steering Column Shaft Boot -- ???
Started by Charley PHX, Today at 02:37:23 PM
Previous topic - Next topic
Charley PHX
Not familiar with this part-- never seen one before?? any thoughts??  https://www.heartbeatcitycamaro.com/23844/1967-1968-1969-Camaro-%26-Firebird-Steering-Column-Shaft-Rubber-Boot/
Description says "This is the rubber boot that goes over the steering shaft swivel joint..." (sounds like it is talking about the rag joint)??
I don't think they are talking about the firewall boot, which is a different part anyway ( https://www.heartbeatcitycamaro.com/16480/1967-1968-1969-Camaro-%26-Firebird-Steering-Column-Rubber-Molded-Seal/ )?
Maybe for the steering column bearing? but it specifically says 'swivel joint'?
'67 04D (LOS) L-35/M20 (-L181A) Convertible (owned since 1975) - Bow Tie 981/1000 GOLD (July 2023)
'67 06D (LOS) L-78 Coupe (body) (1979 barn find) - Gone but not forgotten!
boomer632
Just did mine.. yes that part in first pic was present under the plastic piece on interior. The second pic was not present on either column or rag joints..
06A X66 711 57 57 M22 BU
