Main Menu
tire failure - check the age of your tires
Started by JST69Z28, November 30, 2025, 02:04:36 PM
Previous topic - Next topic
JST69Z28
I posted this as a reminder to all to check your tires and replace if they are old. I was driving home from The Daytona Turkey Run car show Friday in my '69 Z28 when my LF tire blew out.  It had started a vibration about 10 miles earlier, then bang.  See the photos.  Paint damage, etc., now have to be fixed.  Luckily only the car was damaged, plus it happened close to home instead of 100 miles away.  Definitely a wakeup call.  It could have been a lot worse.  The BFG Radial T/As had less than 5K miles on them and looked perfect but were 12 years old.  New tires are going on tomorrow.  Time flies, tires get old and can easily be overlooked.  My friend who I met there has a '66 Impala SS with a brand new $20K paint job, his tires were 14 years old, and he got new ones installed yesterday.  Stay safe.
Vince
Thank you for the warning.   I bet a lot of us hardly ever think about the age of the tires on our cars.
KevinW
On my list for the spring! my tires are older :(
camaronut
The person from Kelsey Tire told me that the recommended time to replace old tires is around 7-8 years.  I'm on my second set of Goodyear repros - keeping a close watch on them.....using 303 coating on them to keep the rubber soft.....but I know a new set is due in a few years.  I don't drive the car much (I know - shame on me), and it's in a garage......so I figure maybe 10 yrs is the furthest I'd go till I get a new set.
Cha Ching!!!!!
JST69Z28
I found out some interesting info yesterday.  I didn't know how to read DOT date codes on tires, now I do.  My new tire serial numbers end in 4424, which means they were made week 44 of 2024, already over a year old when installed.  The one that blew out had a date code of late 2011 but I bought them in early 2013.  The rep at the tire store said this is common for tires because companies may only build a particular tire once a year if it is not a really big seller.  I am also likely going to buy a 5th tire; my wife reminded me that the one I saved as a new spare is still 12 years old and only getting older in the trunk.
