Camaro Research Group Discussion => Decoding/Numbers => Topic started by: DT on August 13, 2012, 08:51:37 PM
Title: 6 cylinder trim tags
Post by: DT on August 13, 2012, 08:51:37 PM
Did the trim tags on a 69 6 cylinder car have 12437 or 12337 ???
Title: Re: 6 cylinder trim tags
Post by: tmodel66 on August 13, 2012, 09:15:48 PM
The trim tag was not connected to 6 or 8 cylinder.  Only VIN reflected whether it was 6 or 8. The "4"  in 12437 was fixed at 4 for '69. The last two numbers told you if it was coupe or convertible. Read about it here
http://www.camaros.org/numbers.shtml#VINvsStyle
Post by: DT on August 14, 2012, 04:41:12 AM
Thanks for the info.  I have a Camaro book that stated the trim tag should read 12337 for a 6 cylinder.  I thought that was incorrect.  problem solved.
