Camaro Research Group Discussion => Decoding/Numbers => Topic started by: chilipepper13 on July 22, 2012, 09:24:59 AM
Title: Strange Block Casting Number
Post by: chilipepper13 on July 22, 2012, 09:24:59 AM
Hi there
Finally assembled all the numbers of my engine today while taking pictures of everything. Something about the engine block casting got me puzzled. My car is a very early 1969 SS/RS 350 (engine build date on the pad stamp indicates Sept 25) and it has the block casting number 3927185 GM 5 T. According to an article on CRG a 1969 350ci block should start with 393 though  ???
Any help would be greatly appreciated! Thanks,
Title: Re: Strange Block Casting Number
Post by: bertfam on July 22, 2012, 09:33:05 AM
3927184 isn't the block casting number. That's the intake manifold casting number.
Post by: Boston14 on July 22, 2012, 09:33:44 AM
The picture you show is the casting number of the Tonawanda cast intake manifold, which is correct for Tonawanda built 350 4 barrel engines.  The block casting number is on the block surface between the bellhousing and intake manifold (behind your coil and distributor).
Post by: Gramps69Z on July 22, 2012, 10:39:44 AM
Here it is.........http://www.camaros.org/drivetrain.shtml#BlockCast
Post by: chilipepper13 on July 22, 2012, 10:55:35 AM
Duh... :-[
Thanks for clarification!
