Camaro Research Group Discussion => Decoding/Numbers => Topic started by: clarkedog on July 11, 2006, 09:27:00 PM
Title: Radiator Question ?
Post by: clarkedog on July 11, 2006, 09:27:00 PM
I have a 69 Z28 and it came with what appears to be a 67-68 radiator .It's an original Harrison radiator with a OD stamped on the right tank. From what I have read it should be CB.Any chance they kept using some OD radiators in 69 or somewhere along the line a previous owner found this radiator and stuck it in.Thanks, Scott
Title: Re: Radiator Question ?
Post by: JohnZ on July 12, 2006, 09:09:05 AM
Probably a replacement - see: http://www.camaros.org/coolingsystems.shtml
Post by: rare4k on July 13, 2006, 07:39:38 AM
The OD that you have stamped on the side tank is from a 67-68 small block . Phil
