Hey guys,
I have a question. For a 69 Camaro with column shifter and no console, could you order a clock? I am trying to decide if I should go with a Speedometer/Clock(center)/Fuel Gauge setup if it would be correct. What about a Speedometer/Fuel Gauge (center)/Tachometer setup. Which setup is correct? Could you order a clock or a tach on a non-console car?
Yes, you could order a clock. In fact I have a cluster just like that.
I believe U16 tach became available right about the time your car was made.
Neither required a console.
So, the Speedometer/clock/Fuel could be had. What about Speedometer/Fuel (center)/Tachometer? I would rather try and keep the tach but if it wasn't an option, I will stay with the other setup.
That's U16.
Thanks for the info Kurt. It looks like I can go either way with the gauge setup. I really like the clock and it is handy, but the tach is cool too. I suppose a Speedo/Clock/Tach setup wouldn't be practical. I am sure when I get ready to install them, it will hit me as to which one I want to go with.
sdkar, speedo/clock/ tach yes impractical w/o fuel gauge
I'm on time, I should shift, I'm not going to get a ticket.
Oh, I'm out of gas...... Yeah, a fuel gauge is recommended.
My 69 has speedo, center fuel guage, and tach with no console. If it had a clock and tach there is no where for the fuel guage without the console. Also note that this setup has only temp and oil lights.
Quote from: sdkar on May 08, 2012, 03:25:03 PM
I have the speedo/fuel center/tach in mine and is perfect! I have like a clock in the iPhone! ;)
...I always cut the battery power when parking so a clock is useless for me anyway...
Kurt, my X44 is an 02D, was that combo I have available then?
No, U16 with the center fuel gauge didn't come out until late April.
But I won't tell anyone.....
Quote from: KurtS on May 12, 2012, 01:20:43 AM
Ha, ha, thanx Kurt it´ll be our secret!!
