Who makes the best aerosol spray can suede paint for a 1969 dash top restoration?
I see lots of formulas and additives for paint shop pro's but I need a already mixed spray bomb option.
Brian
All you have to do with any rattle can is fog it on from about 18". Dries to much the same appearance.
Quote from: william on April 11, 2012, 03:57:21 PM
That's exactly how I did it with my '67 dash annd it came out just right.
Yeah, I used Rustoleum's Satin Black for the top of the dash.
If you are not set up to gun spray, SEM makes an aerosol texture coating. Spray wet or dry to achieve desired effect. Dries dead flat and must be topcated with SEM trim black for proper gloss. Or topcoat it with whatever the car's original color is. SEM is a professional product, unlike hardware store paints. If memory serves, it was also posted here that Krylon make a texture coating. Perhaps firstgenaddict posted pictures of it.
I have never tried to fog when painting - much talent needed? I assume the technique cant be done outside - I need still air?
Quote from: Sauron327 on April 11, 2012, 06:08:05 PM
I looked in a few big box stores for the Krylon mentioned here and on TC but could not find it. Rustoleum had several textured ones but they were all "multi colored" looks like glitter in the mix. Anyone know the current Krylon paint number(s)
All jobbers sell SEM. It's even sold on-line. SEM fries fast and is durable. You won't know how to dry spray(fog) with aerosols like William mentions till you pull the trigger. As I stated, SEM offers a texture coating. Just google their site for all their products. Products chosen and spraying technique is up to you.
Brian - Just follow what William stated to a tee. Get just close enough to the surface to be painted so the suspended paint will stick. The farther away you are the larger the paint particles will be. Play with the distance until you get the desired texture. You can achieve this with just about any rattle paint can out there. Just remember to get full coverage and keep the can/spray moving. This took me about a minute (rust-oleum I had laying around the garage).
Rustoleum dries very slowly and is not the product SEM is. Dry spraying is not difficult, anyone can do it as seen above. The particles are not larger when using the technique, they are simply further from one another and do not combine on the surface tightly and uniformly. The faster a paint dries, the easier it is to achieve the texture. And if you don't want to do it, the SEM texture coating does it for you. I stock it and use it often on various parts.
Quote from: Sauron327 on April 11, 2012, 08:11:21 PM
GEE THANKS! :)
He is right though. Imagine what it would like if I hadn't been blind folded? ;D
My point was that many things can be done, all you have to do is jump in and try.
Thanks guys. I'll give it a try and if it sucks I guess I can always buy the textured paint.
I'm thinking I should give up on the idea of spot repairing the small patch of skud I'm trying to repair and do the whole dash.
I want to leave the glass in which I guess is going to make this a major PITA project.
Quote from: Sauron327 on April 11, 2012, 08:35:38 PM
I agree, and was just yanken your chain.
Also, as for the rust-oleum product, it was just stuff I had laying around the shop. My point was that this suede finish could be achieved with just about anything in a rattle can, it's that simple. I was in no way implying this stuff should be be used on our Camaro's. ;)
When it's time to correct my car I will certainly consider the SEM product you recommended. In addition, does a followup clear coat need to be applied? If the answer is yes, what product do you recommend and at what % of gloss, if any?
Quote from: 69pace on April 11, 2012, 08:55:56 PM
I don't think you can paint it correctly unless the glass is removed.
Krylon camo black worked great for me.
http://www.google.com/products/catalog?hl=en&rlz=1G1GGLQ_ENUS407&q=krylon+camo+black&um=1&ie=UTF-8&tbm=shop&cid=4808345642023151922
I think Year One has all the products you need for the job.
