Hey guys,
I have a 69 Camaro with the rod linkages. It has a big block with a Holley. Would changing out the linkage rods to a cable/bracket setup be considered an improvement? If so, what would be better? Teh factory 6cyl cable setup (which I have) or an aftermarket offering? (Such as Lokar or anyone else). Has anyone done this and what suggestions/advice would you have? Where to buy? Anything else that would help with this?
Thanks for the help.
My 68 has the orginal linkage set up. It has a BBC and I've had everything from a tunnal ram w/ 2X4, to high rise w/ Holley, to the current L71 3X2s (pretty low profile). I've never had a problem with anything I've installed...
