Camaro Research Group Discussion => Originality => Topic started by: john302 on November 27, 2011, 10:31:14 PM
Title: 69 z/28 front spindle inspection marks
Post by: john302 on November 27, 2011, 10:31:14 PM
Does anyone know what the correct inspection marks are for the front spindles , tierod ends, center link for a 69z . The z is a Van nuys early built car 11d. Any info or pics would be real helpful.  thanks alot John
Title: Re: 69 z/28 front spindle inspection marks
Post by: 68camaroz28 on November 27, 2011, 11:12:40 PM
John, believe this to be a NOR car but James supplied some great pics and believe there were some detailing inspection marks. Here is the link just in case if might help.
http://www.camaros.net/forums/showthread.php?t=81626&highlight=brake+hose
Post by: 169INDY on November 28, 2011, 01:07:39 AM
John, I have some detail shots from my underbody restoration and suspension restorations for my LOS build 04C Z11.
Lots of circus paint (inspection duabs) hidden and preserved by years of grime & undercoating NO RUST.
I realize you are asking for a Z & a different month, but was offering anyway if you are so inclined.
Jim W
Post by: john302 on November 28, 2011, 08:55:03 AM
Thanks for the replys. If you have some pics of the z11 that would be great. They are both disc brake cars so I am sure they are the same. thanks alot John
Post by: 169INDY on November 28, 2011, 09:16:42 PM
Let's start here.
SUBFRAME Driver front horn.
(Note Double date stamp hit on this one) (Car is 04C)
Attached.
Post by: 169INDY on November 28, 2011, 09:22:05 PM
Sorry for the double pic post.
Below
SUBFRAME inspection stripe
Post by: 169INDY on November 28, 2011, 09:29:03 PM
tt
Post by: john302 on November 28, 2011, 10:05:49 PM
Thanks for the pics.Are both spindles marked the same? white and orange.Any blue markings? thanks John
Post by: 169INDY on November 28, 2011, 11:29:19 PM
Both sides were very close.
Post by: 169INDY on November 28, 2011, 11:30:22 PM
 tttt
Post by: 169INDY on November 28, 2011, 11:32:22 PM
ttttt
Post by: 169INDY on November 28, 2011, 11:33:19 PM
tttttt
Post by: 169INDY on November 28, 2011, 11:34:06 PM
ttttttt
Post by: 169INDY on November 28, 2011, 11:34:58 PM
tttttttt
Post by: 169INDY on November 28, 2011, 11:35:41 PM
ttt
Post by: 169INDY on November 28, 2011, 11:36:15 PM
tt
Post by: 169INDY on November 28, 2011, 11:36:46 PM
ttt
Post by: 169INDY on November 28, 2011, 11:40:46 PM
Blue on the back side of the two piece front disc
Post by: 169INDY on November 28, 2011, 11:44:43 PM
Here is a little Blue & Yellow on the middle of the drag link.
Post by: 169INDY on November 28, 2011, 11:50:01 PM
Quote from: john302 on November 28, 2011, 10:05:49 PM
I did not find ANY blue on the spindles on my car, blue in other locations, rear end pinion, drag link, & back side of the discs.
On my car I just replaced what I found, with Testors & Pactra model enamel paint and a small brush.
Post by: firstgenaddict on November 29, 2011, 01:35:47 PM
Centerlink and tierod view. 04C Norwood VIN 633599
(http://inlinethumb26.webshots.com/49497/2656981130059464720S600x600Q85.jpg)
Brake Calipers orange paint daub (over the black paint) on left side caliper
(http://inlinethumb09.webshots.com/48840/2805370110059464720S600x600Q85.jpg)
White mark on right caliper (over black paint) was about an inch long
(http://inlinethumb25.webshots.com/46552/2785041370059464720S600x600Q85.jpg)
(http://inlinethumb33.webshots.com/48864/2943909610059464720S600x600Q85.jpg)
Both calipers are dated 105th day of the year.
(http://inlinethumb05.webshots.com/36868/2748993820059464720S600x600Q85.jpg)
Pass Front Purple
(http://inlinethumb02.webshots.com/46657/2794176300059464720S600x600Q85.jpg)
Drivers Side spindle
(http://inlinethumb25.webshots.com/47064/2668917460059464720S600x600Q85.jpg)
Post by: Oaklyss on December 06, 2011, 04:26:28 PM
Heres my front subframe, if it's any help. Date says 3 26 69 on my 04A VN car . My spindles look like the others pictured.
(http://i145.photobucket.com/albums/r206/OAKLYSS/framedate2.jpg)
(http://i145.photobucket.com/albums/r206/OAKLYSS/framedate-1.jpg)
Post by: firstgenaddict on December 06, 2011, 07:14:54 PM
Here are some shots of a Norwood RS/Z Mid March build owned by a member from Clt.
(http://inlinethumb01.webshots.com/49088/2876937060059464720S600x600Q85.jpg)
(http://inlinethumb01.webshots.com/47872/2496141270059464720S600x600Q85.jpg)
(http://inlinethumb51.webshots.com/48370/2781227620059464720S600x600Q85.jpg)
(http://inlinethumb18.webshots.com/3473/2631199660059464720S600x600Q85.jpg)
(http://inlinethumb59.webshots.com/48122/2707630250059464720S600x600Q85.jpg)
(http://inlinethumb45.webshots.com/47980/2277343680059464720S600x600Q85.jpg)
(http://inlinethumb60.webshots.com/47611/2409199860059464720S600x600Q85.jpg)
(http://inlinethumb19.webshots.com/49298/2218655820059464720S600x600Q85.jpg)
(http://inlinethumb16.webshots.com/32847/2111538930059464720S600x600Q85.jpg)
(http://inlinethumb17.webshots.com/46928/2220383760059464720S600x600Q85.jpg)
(http://inlinethumb48.webshots.com/48175/2203836530059464720S600x600Q85.jpg)
(http://inlinethumb33.webshots.com/30496/2077300470059464720S600x600Q85.jpg)
Post by: 69z28302 on December 06, 2011, 09:12:52 PM
Were there frames from both plants stenciled?
Post by: firstgenaddict on December 06, 2011, 09:16:03 PM
I believe they were all made by AO Smith so I am under the impression they did.
Post by: 69z28302 on December 06, 2011, 09:30:46 PM
Quote from: firstgenaddict on December 06, 2011, 09:16:03 PM
Thanks James. I knew from my Mid-Year Corvette buddies that AO Smith made some Corvette bodies but I had know idea on the frame with the Camaro.
Post by: JohnZ on December 07, 2011, 07:49:34 PM
Quote from: 69z28302 on December 06, 2011, 09:30:46 PM
A.O. Smith made 50% of the 1964-1967 Corvette bodies at their Ionia, Michigan plant, and they made ALL Corvette frames from 1953-1982 (1953-1962 and 1968-1982 in Milwaukee, and 1963-67 in Granite City, Illinois. As I recall, the 1967-69 Camaro subframes were made by Chevrolet at the Bristol Road Stamping Plant in Flint.
