Camaro Research Group Discussion => Decoding/Numbers => Topic started by: asm69 on June 17, 2006, 09:06:15 PM
Title: 1969 z/28 clutch pressure plate
Post by: asm69 on June 17, 2006, 09:06:15 PM
Where can I find the casting number or part number or build date on the clutch pressure plate.
Are there any numbers to be found on the clutch disc.
Title: Re: 1969 z/28 clutch pressure plate
Post by: JohnZ on June 18, 2006, 07:00:10 PM
Chances are slim to none that it still has the original GM clutch in it, and the aftermarket clutch manufacturers all have their own methods of marking pressure plates and discs.
Post by: asm69 on June 18, 2006, 10:12:13 PM
The clutch disc itself has GM stamped on the rivet heads. But, I cannot find any identifying
numbers on the clutch pressure plate. It would be nice to know where GM stamped
or cast the numbers on the pressure plate.
Thank you
Post by: JohnZ on June 19, 2006, 08:02:23 PM
GM didn't manufacture their clutches - they bought them from an outside supplier.
