Is there a list or diagram somewhere for all the Body Plugs on a first Gen. Camaro? I see most suppliers list 12 in a set, but I do't think that includes the 2 - 1/2 in. plastic ones for the top of the Cowl. And I have one that's a 1 in. rubber part # 4802102 I think came from somewhere in the Firewall, that is also not in the set. I think I have all of the originals, but some of them were out of the car before I started working on it. They were in a box in the trunk with some other misc. parts. What I can remember;
2 - 1/2 in. plastic in top of cowl (not in set)
2 - 3/4 in. rubber, 1 in each Rocker Panel brace behind Kick Panel
4 - 3/4 in. plastic, 2 in each rear Outer Wheelhouse (front and back)
4 - 1 in. plastic, 2 in each Trunk Floor drop-off
So, I have 10 in set here what am I missing/
Ya don't forget the two under the back seat bottom cushion assembly too. I got the full plug set and I am missing those as well at the firewall and top pf cowl plugs too. Aggravating.
I think there is a 1" plug in the firewall to fill the unused speedo cable hole, depending on transmission.
John
yep
OK, here's an updated list, I have the one that's a 1 in. rubber part # 4802102 I think came from somewhere in the Firewall, that is also not in the set. I think I have all of the originals, but some of them were out of the car before I started working on it. They were in a box in the trunk with some other misc. parts. What I can remember;
1 - 1 inch Rubber part #4802102 goes in Firewall in unused speedo-cable hole.(not in set) I have !
2 - 1/2 in. plastic in top of cowl (not in set) I have !
2 - 3/4 in. plastic, 1 ea. side under back seat
does this look complete?
I may be wrong,but if you have a vehicle with rear antenna, the front piercing also gets plugged (for cable routing for standard front antenna). At least it's plugged at my '67 in this manner.
Anybody have a pic of the 'under the back seat' plugs?
