Camaro Research Group Discussion => General Discussion => Topic started by: 68Zproject on September 26, 2011, 06:38:29 PM
Title: Radiator support
Post by: 68Zproject on September 26, 2011, 06:38:29 PM
Anyone have a trashed radiator support or know where I can get one of these nuts that came off mine?  The first pic shows what the nut looked like and the second shows kind of what the nut looks like that I am missing.  These were clipped in or spot welded and one of mine is gone and I'm trying to get an original that I can weld back in.  I think this is one of the nuts that hold the radiator in, bottom passenger side.
(http://i174.photobucket.com/albums/w112/68zproject/IMG_0262.jpg)
(http://i174.photobucket.com/albums/w112/68zproject/IMG_0263.jpg)
Title: Re: Radiator support
Post by: IZRSSS on September 26, 2011, 06:50:33 PM
I can't help you with the original bolt but if all else fails I hear these guys are pretty good. I've been told they make quality parts w/correct markings and that most restorers use them...
http://amkproducts.com/
Post by: 169INDY on September 26, 2011, 11:44:24 PM
The nut in the bottom picture is a CAGE NUT.
http://www.abcorfasteners.com/Cage%20Nuts.htm
I was not aware Chev used ANY cage nuts at all? Thought the rad nuts both were welded type one flush and one in a pocketed area.
JIm
Post by: MyRed67 on September 27, 2011, 06:03:31 AM
The nut in the top pic. is called a pierce nut.  They were used in several places on a '67 Camaro.  And I believe they were used on the Radiator support.  AMK Products does carry them part #B-10558 for the 5/16 size, they are $4 for 6, problem is though AMK requires a $30 minimum order.  I purchased some and I have a couple extras if you're interested e-mail me.  I'll be reasonable on $.
Post by: JohnZ on September 27, 2011, 09:27:03 AM
Quote from: 169INDY on September 26, 2011, 11:44:24 PM
They didn't - that's an aftermarket fix.
Post by: 68Zproject on September 27, 2011, 11:24:50 PM
Quote from: JohnZ on September 27, 2011, 09:27:03 AM
That's correct.  I added that as it looked better than what was on it.
Post by: 68Zproject on October 17, 2011, 12:11:09 PM
So John, do you know how these were affixed to the R.S?  If I can get one from Red, I want to put it back the way it came if possible.
Post by: JohnZ on October 18, 2011, 09:33:36 AM
Quote from: 68Zproject on October 17, 2011, 12:11:09 PM
"Pierce-nuts" were installed in a press operation with male and female dies; the dies created a rectangular hole and crimped flanges on the ends of the nut over the ends of the hole.
Post by: jcfcamaro on October 18, 2011, 04:04:45 PM
I have a old support off my 67 rs ss  , don't know if I need it for my repo support or not,  What does this hold ?
Post by: MyRed67 on October 18, 2011, 09:59:17 PM
69Zproject>>Top pic. are we looking at the Radiator support from the front?  If so, you will install the AMK Pierce nut from the front, wide part out and narrower part in.  You will probably have to give it a little "LOVE" tap to get it completely in place.  You could just bolt it together at this point.  I would (or did, where I used them) put a heavier Hammer on this wider side, and then "peen" the corners a little on the other side to make a more permanent  fix.  Less chance of the nut coming loose if you would ever take apart again sometime.
Post by: 68Zproject on October 19, 2011, 10:48:21 AM
I haven't looked at this in a while, but I'll probably remember when I see the nut.  I'm going to wait until I get my radiator re done and then I'll replace this missing nut. I've got an original radiator I'm cleaning up to put back in. Thanks much.
