I'm looking for the rubber grommets that the shifter rods go into on my muncie shifter linkage. I can't find them anywhere. Does anyone know of a good place to buy them?
You might try these guys...It's in PDF format so give it time to load:
http://www.drclassic.com/images/catalogs/pdf/Camaro/Transmission.pdf
Quote from: wisemanz28 on September 16, 2011, 04:20:03 PM
If you are talking about a OEM Hurst shifter that originally had molded in place vibration isolators, try Pete at Presision Pontiac. Scroll down.
http://www.precisionpontiac.net/Products.aspx
If it is a aftermarket shifter Summit Racing has steel or nylon bushings for those.
http://www.summitracing.com/parts/HUU-3327302/
Thanks so much guys, I've been looking for these grommets a long time.
the 1970 and up replacement rubber bushing insert , you can still get from Chevy.
It was used for many years on all types of applications.
Many use the insert to restore 1969 shifters but 1969 originally used a molded on rubber bushing
Quote from: JoeC on September 20, 2011, 07:06:20 AM
do you have a part number on those grommets?
