Camaro Research Group Discussion => General Discussion => Topic started by: Dusk_Blue_Z on September 13, 2011, 10:26:08 AM
Title: Low Oil Pressure Indicator
Post by: Dusk_Blue_Z on September 13, 2011, 10:26:08 AM
Can someone tell me at what PSI does the 'Oil' light come on in the dash?
Thanks, Nick
Title: Re: Low Oil Pressure Indicator
Post by: tmodel66 on September 13, 2011, 11:05:33 AM
I think it's around 7 pounds if I remember correctly.
Post by: bertfam on September 13, 2011, 12:54:02 PM
There are several variables, but on average, the light will come on around the 4 to 5 PSI range. Chevy engines require approx 1 PSI for every 100 RPM, so if you're at a 700 RPM idle you "should" have an absolute minimum of 7 PSI oil pressure. Anything lower than that and the lamp will start to flicker. If it's really low (around 4 to 5 PSI), the lamp will stay solid.
Post by: Dusk_Blue_Z on September 13, 2011, 01:07:23 PM
Great, thanks for the info.
