Camaro Research Group Discussion => General Discussion => Topic started by: cadmanof50s on June 24, 2011, 02:08:29 PM
Title: Rear Axle Carriers
Post by: cadmanof50s on June 24, 2011, 02:08:29 PM
I have not been able to find any thing in-the CRG site on the different carrier series.
Is there a link that explains the differences and how one can identify which is which.
Thanks!
Vic
Title: Re: Rear Axle Carriers
Post by: bertfam on June 24, 2011, 02:49:02 PM
Vic, there will be a casting number on the carrier. Post that number and we can tell you what you have.
Post by: cadmanof50s on June 24, 2011, 05:49:03 PM
Thanks Ed,
I did have this number from an old picture I took a while back. But this is the Axle Code: BP0228G2 which tarnslates (below). I will get the casting number when I crawl under the car tonight.
Thanks!!
(Since 1968) it is a 2.73 Ratio 10 bolt - not posi
Built February 28th (1968)
at the Detroit Gear & Axle plant
in Shift 2
Vic
Post by: cadmanof50s on June 24, 2011, 07:39:45 PM
The casting number is 3894859 NF.
Post by: bertfam on June 24, 2011, 08:13:40 PM
Vic, the 3894859 is the casting number of the center section (some call it the "pumpkin") on the 10 bolt rear end. You can read more HERE (http://www.camaros.org/drivetrain.shtml#axle).
Post by: cadmanof50s on June 24, 2011, 08:54:56 PM
Sorry Ed. This shows my ignorance.
Where do I look for the carrier casting number?
Do I have to remove the differential back cover to determine which series is in the rear axle?
Post by: bertfam on June 24, 2011, 09:47:38 PM
The 2.73 axle used a 2 series carrier, so if the car still has this gear set, no, you don't have to remove the cover.
Post by: cadmanof50s on June 24, 2011, 09:50:16 PM
Thanks for the info Ed.
Vic
